SSO to OWA from site using Integrated Authentication
mappoc
Currently we use Integrated Authentication on our website. Once logged on, there's a link to OWA (2003) " https://www.mycompany.com/exchange/mappoc" , which is installed on the same server. When our users click the link, their credentials are automatically passed and their OWA opens.
We're moving to Exchange 2010 and OWA will now be on a separate server. What's the best way to accomplish the same SSO effect? We are not using ISA. I've enabled IA on the OWA (2010) virtual directory, but that clearly wasn't enough. Any help would be appreciated. Thanks.
-- Mark
Steve Goodman
Does it work if you make sure the domain *.mycompany.com or the mail server new name is added to Internet Explorer's intranet zone?
Steve
Steve Goodman
G
Gavin-Zhang
Hi Mark,
Do you mean that you want to the achieve the OWA SSO when the exchange 2003 and excahnge 2010 coexistence scenario?
Per my known, if you want to have the user experience the smoothest transfer from the exchange 2010 server logon page to the excahnge 2003 mailboxes using Single Sign On, you must have Forms Based Authentication enabled on the exchange 2003 Front End server . If you do not have FBA enabled there, see the detailed instructions on how to configure FBA in an exchange 2003 environment see tne article:
http://technet.microsoft.com/en-us/library/bb123832.aspx .
Regards!
Gavin
Brian Day MCITP
'How did you do it? Did you use Set-OwaVirtualDirectory <identity> -WindowsAuthentication $True or did you try to do it manually through IIS? You'll also need that URL to be part of the browser's Local Intranet security zone so pass-through auth will work.Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
K
KirkSH
Is it possible on this issue to enable the end user to simply go to the url for OWA on your CAS server and get SSO no matter whether their mailbox is on 2003 or 2010 in a coexist environment?
T How to get Exchange 2003 OWA SSO authentication to work with Internal TMG Array web listener Exchange Server Administration 1
J OWA vs. Outlook 2016 Bandwidth Exchange Server Administration 1
Diane Poremsky New Office365 Feature: URL Preview in OWA New Slipstick.com Articles 0
S Cannot disable OWA light Exchange Server Administration 5
J Stuck using OWA Exchange Server Administration 0
T Outlook Calendar Sync MY GOAL: see work calendar on home desktop w/o OWA Using Outlook 2
T Sync OWA? Exchange Server Administration 0
O Multiple simulteniously opened OWA 2010 accounts in one browser work fine ! Using Outlook 3
S Newly added user doesn't show up in GAL but available in OWA, Using Outlook 0
B OWA Calendar Views not available Exchange Server Administration 2
B Searching OWA Additional Mailbox - in which Secondary folder is the email? Using Outlook 1
D OWA and Windows 8 Exchange Server Administration 1
Z OWA Mailbox unavailable Exchange Server Administration 2
R Lost Outlook 2007 message found in OWA Using Outlook 4
D OWA Send invitation AS (not from) Exchange Server Administration 1
E OWA phones home too much? Exchange Server Administration 1
S Cannot open any attachment from OWA Exchange Server Administration 2
T Syncing OWA 2010 to Outlook 2007 Exchange Server Administration 15
R OWA can't delete mail Exchange Server Administration 8
J Outlook and owa access Using Outlook 1
S Track emails in OWA Exchange Server Administration 1
T OWA and post dating Exchange Server Administration 1
S Unable to Sync Phones but OWA connects Exchange Server Administration 1
B [SOLVED] Forced to type Domain/username for OWA 2003 with IE 7 or 8 Exchange Server Administration 3
M Attachments cannot be opened in Outlook, OWA works fine Using Outlook 2
T OWA Folders Using Outlook 0
A Managing GAL via OWA Exchange Server Administration 5
J Mail read in OWA won't appear in Outlook Exchange Server Administration 1
1 mobile OS or apps for sync of all OWA/exchange PIM functions Exchange Server Administration 3
A OWA Certificate Expired Issue Using Outlook 1
C OWA 2010 Nicknames Multiply Using Outlook 3
S Signature size limit for OWA / Exchange 2010 Exchange Server Administration 10
T Military OWA on Outlook Using Outlook 1
T owa Exchange Server Administration 2
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
J OWA 2010 Sp1 custom themes Exchange Server Administration 2
L User not shown in Adressbook but is shown in Adressbook using OWA Exchange Server Administration 6
K OWA breaks after moving mailbox to exch 2010 Exchange Server Administration 6
J Missing options in OWA Premium 2007 for some users Using Outlook 0
B OWA 2010 FBA Exchange Server Administration 2
N OWA: email flags not showing Using Outlook 1
owa
