Purchase Ex-2010 - Want to install ex 2007 - Product Key issue
Ashfaque Deshmukh
I have purchased Exchange 2010 standard version for company however I want to install Exchange 2007 due to incompability of hardware. Please advise me how I will get the product key changed.
Thanks in anticipation.
Your answer for the same would be highly appreciated.
Ashfaque Deshmukh
Busbar [MVP]
what is not incompatible, if you can run Exchange 2007 on the HW 2010 should be able to run it.
anyway you will need to purchase downgrade license to be able to install 2007
Regards, Mahmoud Magdy Watch Arabic Level 300 Videos about Exchange 2010 here: http://vimeo.com/user3271816 Read pretty advanced Exchange stuff I post here: http://www.enowconsulting.com/ese/blog.asp, follow my blog: http://autodiscover.wordpress.com , corp blog: http://ingazat.wordpress.com, Follow me on twitter http://www.twitter.com/_busbar and if you Liked my post please mark it as helpful and accept it as an answer
Sembee [MVP]
There is no hardware compatibility issue between Exchange 2007 and 2010. As you must use a 64 bit machine (32 bit isn't supported for production if that is your hardware issue) then it will support both versions.
I believe that downgrade rights only come with volume licences, not retail. Therefore as long as you have a volume licence you should be able to get the key through the volume licencing site or by your reseller requesting a media kit. If you bought retail box, then you have no downgrade rights as far as I am aware - but speak to Microsoft to confirm.
Although personally I would look again at the hardware issue. If it is purely the 64 bit problem then Exchange 2007 isn't going to help, because you can't licence the 32 bit version.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
James-Luo
For the questions about licensing, please use the contact information in here which would be the best place for you to find the answer
James Luo
D If I purchase Outlook 2010, will I be able to incorporate all of my previous Outlook Express files? Using Outlook 1
J Send a request to purchase to several purchase agents, only one acts. Using Outlook 3
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
R Outlook 2010 How do you export 2 email Accounts' 2010 Inbox Files to new computer (2019)? Using Outlook 1
F how do i set a reminder in onenote 2010 Using Outlook 8
David Michaels VB coding works in OL 2010, but not in OL 2013 Outlook VBA and Custom Forms 4
