Re: Get-CASMailbox not returning same result with Server side filtering and Client side filtering?
  • Thread starter Ed Crowley [MVP]
  • Start date
E
Ed Crowley [MVP]
Neither of those gives you a count. In my test, the first one returns nothing (null) and the second returns a collection of mailboxes. Your first one is apparently not supported (even if it works in Exchange 2007) since OWAEnabled isn't on the list of filterable properties in this document http://technet.microsoft.com/en-us/library/bb738155.aspx, which links to the Exchange 2007 equivalent http://technet.microsoft.com/en-us/library/bb738155(EXCHG.80).aspx.
To get the count, you'd enter:
$Count= (Get-CASMailbox -ResultSize Unlimited | Where {$_.OWAEnabled}).Count
(The -eq $True isn't required.)
Ed Crowley MVP " There are seldom good technological solutions to behavioral problems."
L
Laeeq Qazi
Thanks Ed for your reply.
I mistakenly wrote
$count
instead of
$count.count
Also this page http://technet.microsoft.com/en-us/library/bb738155(EXCHG.80).aspx. does have " OWAEnabled" as filterable porperty for Get-CASMailbox.
If webpage for " Filterable Properteis in Exchange 2010 SP1" references the same page for Exchange 2007, then it should imply that all the filterable properties should work on Exchange 2010 too.
This ps line
$count = Get-CASMailbox -filter {OWAEnabled -eq $True} -resultSize Unlimited
does return collection of PSObjects on my Exchange 2010 (both RTM and SP1), but less than the actual number, while on Ex2007 it is running fine. Also the important point is that the same ps command is running accurately on Ex10 for other protocols, like POPEnabled, IMAPEnabled etc. It's only having problem with OWAEnabled. Thats strange.
You know server side filters are always fast if we compare to client sider filtering.
Regards,
Laeeq Qazi|Team Lead(Exchange + Sharepoint + BES + DynamicsCRM) www.HostingController.com
E
Ed Crowley [MVP]
You are welcome to contact Microsoft Support and open a bug.Ed Crowley MVP " There are seldom good technological solutions to behavioral problems."
oliv- .RESTRICT returning birthdays regardless of the filtering date Outlook VBA and Custom Forms 8
P Mail delivery failed returning message to sender Using Outlook 1
G Outlook 2013 - Search Returning All Calendar Entries Using Outlook 1
D when trying to send mail a box comes up entitled: ENTER NETWORK PASSWORD and keeps returning over & over again even if I shut computer down Using Outlook 1
A Two Inboxes, Same Email? Using Outlook 3
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
N Move emails of same conversation to same subfolder Using Outlook 6
I get count of all emails with same conversation ID Outlook VBA and Custom Forms 2
R Shortcut for attaching the same file repeatedly Using Outlook 6
M warning for too many appointments on a same day in Outlook Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
M Why delivery receipt size is same than sent email size or even larger? Using Outlook 1
C How to copy same text header to multiple emails with custom text column Using Outlook 10
D Calendar - color coded items are now the same color Using Outlook 2
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
B Mail on both laptop and mobile at same time Using Outlook 2
M Can't open same msg file more than once at the same time in Outlook 2010 Using Outlook 7
L Delete code and commandbutton at the same time. Using Outlook 1
njs27 Start date of occurrence same as PatternStartDate Outlook VBA and Custom Forms 6
G How to let data in an account user defined field appear in the same field all related opportunities BCM (Business Contact Manager) 1
L IMAP and POP email in same Outlook system Using Outlook 1
A Use same BCM data in 2 offices BCM (Business Contact Manager) 3
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
K Help! I selected every contact and mistakenly made them all the same category Using Outlook 1
S Searching contacts across GAL and local address book at same time Using Outlook 1
D Move email to same folder as the rest of the conversation Using Outlook 1
J How to create fields that will use the same value on different record types BCM (Business Contact Manager) 2
R View two Inboxfolders at the same time in split creen Using Outlook 1
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
D ActivitiesTab in OL2000 - same functionality in OL2013? Using Outlook 1
B Excel 2010 vba to post appts to different outlook calendars at the same time Using Outlook 6
J outlook problem it allow to book meeting room at the same day & time Using Outlook 0
Z Keep Unread Messages in same folder Using Outlook 2
D Multiple Users Updating Custom Form At Same Time Using Outlook 1
K Save a received email in a mailbox subfolder which is the same as the @email Using Outlook 1
Commodore Renamed folder staying at the same position Using Outlook 3
E "Current View" settings across multiple users on same Exchange 2007 account. Using Outlook 1
A In Contacts Phone List View, allow alpha jump w/single key, same as Card views Using Outlook 4
P Different names for the same email address Using Outlook 1
L HOw to get rid of multiple recurrent appointments that are all the same Using Outlook 1
K Need to get OOO messages more than once for the same email box Using Outlook 2
