Retention Policy Tags (Delete and Allow Recovery) Inbox and Sent Items
P
psifur
I want to use MRM in the following scenario:
DPT Move to Archive older than 90 Days.....to include Inbox and Sent Items folders RPT Delete and Allow Recovery older than 1 Year (Inbox, Sent Items Only)
From my research this doesn't seem possible...If an RPT is deployed against Inbox and Sent Items, will the DPT Move to Archive work in moving items in those specific folders to the archive?
Brian Day MCITP
You can't have a DPT and RPT apply to the same folder. If you assign a RPT to Inbox and Sent Items, then the DPT within the Retention Policy will not apply to them since they already have a PT affecting them. Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
My posts are provided “AS IS” with no guarantees, no warranties, and they confer no rights.
M SP1 retention policy tags Exchange Server Administration 1
N Outlook dialog about retention policy Using Outlook 3
J Retention Policy Deficiencies Exchange Server Administration 1
P Archive Policy/ Retention policy in Exchange 2010 Exchange Server Administration 2
B Retention policy for online archive itself. Exchange Server Administration 1
D Retention Policy Inheritance Exchange Server Administration 2
S Retention Policy not working?? Exchange Server Administration 35
S Re: SP1 Retention Policy behavior Exchange Server Administration 2
A Exchange 2010sp1. Retention policy will not delete messages from "deleted item" Exchange Server Administration 11
T -basefolderonly still apply when creating a new retention policy in Exchange 2010/sp1? Exchange Server Administration 6
R Default Archive and Retention Policy requires Enterprise CAL? Exchange Server Administration 3
L Clear Deleted Items Automaticly with Retention Policy doesn't work. Exchange Server Administration 3
M Exchange 2010 SP1 adding retention policy via outlook 2010 Exchange Server Administration 7
M Ex 2010 SP1 retention policy question Exchange Server Administration 4
Z Retention policy execution Exchange Server Administration 2
S Pre SP1 using Managed Folders Policy - Post SP1 what do I do? Retention Policy? Exchange Server Administration 2
C Exchange 2010 Retention Policy not working Exchange Server Administration 8
A Retention Policy Exemptions Exchange Server Administration 2
A Mailbox Retention Policy Exchange Server Administration 1
S Retention Policy Clarification Exchange Server Administration 5
F Default retention policy - how to Exchange Server Administration 3
R Retention periods and Deleted Items Using Outlook 7
I Retention policies on outlook 2016 ribbon Using Outlook 2
K How do retention policies work with .pst files? Using Outlook 9
T How to Assign Retention Tags for Notes Items in Exchange/Outlook 2010? Exchange Server Administration 0
D Exchange 2010 User License with Retention Policies Exchange Server Administration 3
A Exchange 2010 SP1 RU1 Calendar Retention Exchange Server Administration 1
S 2010 SP1 Retention Policies Exchange Server Administration 5
K Retention Tags - expired items not deleted from Deleted Items Exchange Server Administration 21
T Exchange 2010 SP1 - Managed Folders / Retention Policies Question Exchange Server Administration 4
D Retention Policies when do they run Exchange Server Administration 1
R Retention and deleting Exchange Server Administration 1
A Inbox Retention with Subfolders Exchange Server Administration 4
T Exchange 2010 Archive Retention Exchange Server Administration 8
B Exchaneg 2010 SP1 Possible Bug, Cannot create move to archive retention tag on inbox, but can create a new one and edit and assign inbox to it Exchange Server Administration 3
L Calendar archiving policy Exchange Server Administration 1
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
K Autoarchive when contradicting company policy Using Outlook 3
J How to get throttling policy statistics for users Exchange Server Administration 2
S Email Address Policy Bug?? Exchange Server Administration 5
D Exchange 2010 SP1 Policy to Delete mail in deleted items older than 30 days Exchange Server Administration 2
E Policy for set pst file as default. Exchange Server Administration 1
N Recipient Policy not applying Exchange Server Administration 1
H Use group policy to block access to modify account settings outlook/exchange 2010. Using Outlook 1
A Exchange 2010 Room Mailbox Policy Not Applying Correctly Exchange Server Administration 1
I Outlook 2010 Archiving Assign Policy Greyed out Using Outlook 1
S Determine Managed Folder Policy for Mailbox in Powershell Exchange 2010 SP1 Exchange Server Administration 4
F Email Address Policy for External Recipients in Exchange 2010 Exchange Server Administration 2
S Applying Managed Folder Policy using Powershell Exchange Server Administration 2
