DR site resiliency design with Exchange 2010 - shared or different namespace for cas.
K
kcrxs30
We are creating a DR site at remote location (active/passive model). This will be a passive site (passive databases with stretched DAG) only to be used in case of disaster for complete site failover. I am wondering if we should go with shared/same namespace (mail.company.com) or separate/different namespace (dr.company.com) for DR site? It seems from Microsoft best practices, they advise separate namespace but no clear documentation and steps guide with it. How will failover affect the exchange services (outlook, owa, eas, outlook anyware, ActiveSync., autodiscover, cas array). Any advice/comments/experience are appreciated.
kc
N
Neil Hobson
I just responded to this then my browser hung (again!) so hopefully you won't see a double post. Can't remember exactly what I typed but the gist of it was that you'll get many different viewpoints but what I like about different namespaces is that you can test OWA/EAS/etc via a different URL (dr.company.com/owa) without affecting the production service, as long as you've got a 'test' database failed over to the DR site (or you test a specific production database)
With datacenter switchovers you basically change the external DNS records to point to the new DR site. Check out the link below and post back with any specific questions...
http://technet.microsoft.com/en-us/library/dd351049.aspx
Principal Consultant, Silversands | www.silversands.co.uk | www.msexchange.org/neil_hobson
D DAG for site resiliency Exchange Server Administration 4
S Create DAG for DR or site resiliency Exchange Server Administration 4
D Removing multiple Exchange 2007 servers on the same Domain and site Exchange Server Administration 1
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
O How do I failover to my DR Site. Exchange Server Administration 13
J Cross AD Site Free Busy / Availability Issue Exchange Server Administration 3
S DAG Deployment Design with site resiliance Exchange Server Administration 2
X Single AD site with DR Exchange 2010 Exchange Server Administration 6
S Exchange 2010 Design Consideration in Multi Site Topology Exchange Server Administration 3
B Active Active Site Resilience Exchange Server Administration 3
D I can't set up my account because the site does not accept my email account Using Outlook 2
P Exchange 2010 SP1 Cross Site CAS connection disable Exchange Server Administration 2
S Exchange 2010 - Out of Office not working - MAC Entourage cannot connect to EWS (Default Web Site) Exchange Server Administration 1
C Site resilient exchange 2010 design Exchange Server Administration 3
S When I recieve mail, if I click on a site in the mail, it will not let me go to the site. It tells me 'This operation has been canceled due to re Using Outlook 2
D outlook folder contents not syncing with hotmail site Using Outlook 1
S single DAG two AD sites cross site database failure Exchange Server Administration 3
Z Exchange 2010 Site Resilient Deployment issue (Important) Exchange Server Administration 1
B dual site DAG configuration Exchange Server Administration 2
M Cannot relay emails to a remote AD site Exchange Server Administration 2
B OWA issues (CAS Proxying - Site to Site) Exchange Server Administration 4
M SSO to OWA from site using Integrated Authentication Exchange Server Administration 5
S One CAS Array for mulitple site Exchange Server Administration 2
C Multiple CAS servers in different sites - one Reverse Proxied site? Using Outlook 1
J DAG for site resillience Exchange Server Administration 4
J DAG for site resillience Exchange Server Administration 3
B Do we need to create a CAS Array for a single server site? Exchange Server Administration 3
P Looking for suggestions regarding a multi-site high availability/disaster resistant design Exchange Server Administration 1
M When I receive email with links to web site it tell me that I need to contact an administrator Using Outlook 1
E Exchange 2007 multi-site cluster and load balancing Exchange Server Administration 2
G Exchange and Multi-Site AD Exchange Server Administration 14
P Exchange 2010 Mailbox Resiliency question Exchange Server Administration 10
J Outlook Contacts - Design This Form Outlook VBA and Custom Forms 2
R How to design custom template under message/mail form ! Using Outlook 0
O Outlook Holiday Request Form Design Using Outlook 0
J Form design - how do I insert an automatic date/time field? Using Outlook 2
E Exchange 2010 - after sending a draft it is still available in the Dumpster - is this behaviour by design? Exchange Server Administration 4
Z Design sizing? Exchange Server Administration 3
D CAS Design Question Exchange Server Administration 4
T Poor User Design on Outlook 2010 Calendar View Using Outlook 1
J Is it still true you cannot design a custom form with BCM 2003?? Using Outlook 1
S Exchange 2010 DAG design - Drp Exchange Server Administration 2
S Exchange Server 2010 Design & Hardware Requirement for 1500 mailboxes Exchange Server Administration 5
A What is the recommended storage lun design for databases and T-logs ? Exchange Server Administration 4
O Exchange 2010 Design question Exchange Server Administration 4
T Exchange 2010 Hardware Design Exchange Server Administration 1
Z Exchange 2010 SP1 Hyper-V Virtualization Design Consideration Exchange Server Administration 7
