Problem with Search-Mailbox Query
V
Veichtlbauer
I want to perform a rather simple task in user's mailboxes: deleting all messages received before a certain date. This is on Ex2010 SP1, and as per documentation, the search string is in Advanced Query Syntax .
Search-Mailbox -Identity " user" -SearchQuery " received:<01/01/2010" -DeleteContent
When I run that command, however, I get an error message as follows:
+ CategoryInfo : InvalidArgument: :)) [], ParserException
+ FullyQualifiedErrorId : 339B33A9
What am I doing wrong here, I don't quite understand? Followed the reference to E-Mail properties here: http://www.microsoft.com/windows/products/winfamily/desktopsearch/technicalresources/advquery.mspx, and the Search-Mailbox docs here: http://technet.microsoft.com/en-us/library/dd298173.aspx.
V
Veichtlbauer
Yes, that role is assigned to the account. If I execute the command without the -SearchQuery parameter, it executes just fine. The problem indeed seems to be the AQS string " received:<01/01/2010" , in particular the colon. When I remove the colon, I get an error that the " less then" operator must not be used in conjunction with a keyword. If I remove that operator as well, the command returns no error, but doesn't actually do what I want it to (rather obviously).
F
Frank.Wang
Hi Veichtlbauer,
I test it in lab and it works.
First, I test Search-Mailbox -Identity " user" -SearchQuery " received:01/01/2010" -DeleteContent
And the mails received on 01/01/2010 will be deleted.
Then I test Search-Mailbox -Identity " user" -SearchQuery " received:<01/01/2010" -DeleteContent
The mails received before 01/01/2010 will be deleted.
From your description:" If I remove that operator as well, the command returns no error, but doesn't actually do what I want it to"
Do you mean the mails you received on 01/01/2010 has been deleted?
What " Region and Language" do you set?
Frank Wang
V
Veichtlbauer
Hmm, then something about my setup must be wrong then? I used the exact same syntax as you, and it resulted in the error:
Das Eigenschaftsschl&uuml;sselwort wird nicht unterst&uuml;tzt.
+ FullyQualifiedErrorId : 3241D4D1
To clarify:
When I use the syntax below, I get no error message, the mailbox gets searched, but no elements are deleted (that ought to be because the search criteria are not very logical...):
Search-Mailbox -Identity g.veichtlbauer -SearchQuery " received 01.01.2010" -DeleteContent
The server is using German (Austria) locale, but it doesn't work even when I use the German date format. Somehow it does not seem to like the colon in the AQS though...
F
Frank.Wang
Hi Veichtlbauer,
According to the error message: " Das Eigenschaftsschl&uuml;sselwort wird nicht unterst&uuml;tzt." ->The property keyword isn't supported.
The error will be occur if you enter a wrong(unsupported) property.
Did you try other properties, e.g: From, Subject...
Details: Understanding Exchange Search
http://technet.microsoft.com/en-us/library/bb232132.aspx
My lab is English(US) format. Sorry I haven't a German language Exchange to test.
Frank Wang
V
Veichtlbauer
Argh! I wasn't aware that the search string is completely localized, even the keywords!
So this one works just fine:
Search-Mailbox -Identity " user" -SearchQuery " empfangen:<01.01.2010" -DeleteContent
Thanks for hinting in the right direction, I am so blind :)
D Icloud Outlook 2010 Task/Reminder Search Problem Using Outlook 1
W Microsoft Outlook 2010 Instant Search Encountered a Problem While Trying to Display Results. Using Outlook 1
C Problem with Free/Busy search of an Exchange user from GroupWise Exchange Server Administration 5
P Problem with a Search-Object resulting from an AdvancedSearch Outlook VBA and Custom Forms 2
B Problem with import Excel BCM (Business Contact Manager) 1
chupacabra Problem with IMAP .pst file Using Outlook 13
