Mailbox Export Import issue on Exchange 2010 SP1
Jeevan Singh Negi
Dear Experts,
i am facing issue on mailbox export and import on exchange 2010 sp1
we have exchange 2010 sp1 on our all CAS and MBX server, also i run below mention command and rights give to security group and map the admin account on it but still i am not able to export the mailbox data on PST, UNC path is also there and full control on Exchange trusted
New-ManagementRoleAssignment -Name " Import Export_Enterprise Support" -SecurityGroup " Enterprise Support" -Role " Mailbox Import Export"
we have cas array on CAS server
can you please let me where is the issue
Couldn't connect to the source mailbox.
+ CategoryInfo : NotSpecified: (0:Int32) [New-MailboxExportRequest], RemoteTransientException
+ FullyQualifiedErrorId : A4253761,Microsoft.Exchange.Management.RecipientTasks.NewMailboxExportRequest
i also run the same command on verbose mode
below is the error for this
MapiExceptionNetworkError: Unable to make connection to the server. (hr=0x80004005, ec=2423)
Jeevan singh
C
Christian Weihs
Hi Jeevan Singh Negi,
How long did you wait after you entered this command? Exchange is caching
permissions and you should wait at least two hours.
Otherwise restarted the IS...
Best regards
Christian
You can also google " Mailbox Cache Age Limit=REG_DWORD:120" to get more
informations...
Jeevan Singh Negi
hi,
i run this command on yesterday, and server also restart after that
Jeevan singh
C
Christian Weihs
Ok, That is long enought! ;-)
Try to connect directly to the CAS-Server.
This should solve your issues...
Best regards
Christian
G
Gavin-Zhang
Hi Jeevan singh,
Any update for your issue?
Above gave a good suggestion, I also run into the same issues before, if you use the cisco LB, you also could enable source NAT'ing on the LB.
Regards!
Gavin
J Import/Export Mailbox issue Error: -2147467259 Exchange Server Administration 1
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
C Outllook Migration - Office 200? - 2010 - Shared Mailbox Export-Bulk 500 users Using Outlook 1
C mailbox-export (exchange 2007) new-mailboximportrequest (exch2010 SP1) missing calendar re Exchange Server Administration 8
T Exchange 2010 SP1 Mailbox export date filter problem - bug? Exchange Server Administration 9
C Your mailbox has been temporarily moved ... Using Outlook 2
A New email notification on shared mailbox Outlook VBA and Custom Forms 0
N Shared mailbox in cached mode Using Outlook 0
F How to show assigned tasks under certain mailbox? Using Outlook 4
S Import contacts to a shared mailbox Outlook VBA and Custom Forms 2
D Delete Emails from Senders in Shared Mailbox Outlook VBA and Custom Forms 1
O Office 365 - Outlook - Password protect your mailbox Using Outlook 7
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
M other user's mailbox won't open, forms disappeared Using Outlook 42
M Mailbox Size Outlook.com or Outlook 2011 Using Outlook 1
K Lost Rules. Assistant accesses my mailbox. Disappeared Using Outlook 0
S Recovering permanently deleted folder from shared mailbox Using Outlook 1
I Application_NewMailEx for shared mailbox Outlook VBA and Custom Forms 1
Diane Poremsky Monitor secondary mailbox folder for new messages New Slipstick.com Articles 0
Mark White vba to create a shared mailbox folder Outlook VBA and Custom Forms 3
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
oliv- Treat once an email with the ItemAdd event in a shared mailbox Outlook VBA and Custom Forms 2
K VBA to measure response time for each emails in a shared mailbox Outlook VBA and Custom Forms 11
M Upgrade in Progress. Your mailbox is currently being optimized as part of upgrade to Outlook 2010 Using Outlook 9
S Shared Mailbox Alert Outlook VBA and Custom Forms 7
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
P Migrate Office 365 mailbox to a different on-premises domain Using Outlook 1
T Checking mailbox emails Outlook VBA and Custom Forms 0
F Room Mailbox Reply Exchange Server Administration 0
L Wishlist Archive mailbox - folder expansion Outlook Wishlist 2
D Shared Mailbox with mail item marked as "private" Using Outlook 0
Diane Poremsky Save Sent Items in Shared Mailbox using an Exchange Server Cmdlet New Slipstick.com Articles 0
Diane Poremsky Sending Email from a Secondary Exchange Mailbox New Slipstick.com Articles 0
J Automatically Move Old Items from a Shared Mailbox to a .PST on a Network Drive Outlook VBA and Custom Forms 1
P Viewing Meeting Organizer on room Mailbox Using Outlook 1
Van Fog Get items in search folder for shared mailbox Outlook VBA and Custom Forms 3
I shared mailbox - can i create a rule (vba) for every user? Outlook VBA and Custom Forms 1
