Exchange 2010 does not updat GAL since few days
Marmar1870
I have recently created a new user with a new mailbox on my exchange 2010 server (Windows 2008 R2) , the user did not show in the GAL but only in all users , the user can access his mailbox fine through OWA , but when we try to connect to outlook 2007 we get the error message " The Name cannot be matched to a name in the address list" when i try to force GAL to update using power shell i got the following
{[PS] C:\Windows\system32>Update-GlobalAddressList -Identity " Default Global Address List" -Domaincontroller " Exchange2010"
WARNING: The recipient " Egytrav.local/Microsoft Exchange System Objects/Schedule+ Free Busy Information - First Administrative Group" is invalid and couldn't be updated.
WARNING: The recipient " Egytrav.local/Microsoft Exchange System Objects/Offline Address book - \/o=new
egytrav\/cn=addrlists\/cn=oabs\/cn=De" is invalid and couldn't be updated.
[PS] C:\Windows\system32>}
I checked everything that could cause this problem but failed to find any reason, this happen only few days ago since a week i have created a new user & mailbox without any problem , so i tried to check windows recent update & i found that there was update since 5 days is there any possibility that one of these updates mis any setting in security & permission to cause this problem?
Please Help, this is urgent
Marwa
Marwa
C
Christian Weihs
Hi Marwa,
mail-disable the public system folder for the free busy informations.
After this you should be able the update the GAL again...
Best regards
Christian
Allen Song
You can open Public Folder Management Console, then expand System Public Folders, find the relevant entry for Egytrav.local, then try to remove it.
After that, please check this issue.
Allen
Allen Song
Marmar1870
I have disabled mail on public folder & was able to use commands to update GAL and Offline Address Book with no errors but still same way no new user appear in GAL & hence not able to connect via outlook , but using web exchange is fine & i can find all the new user up to date , any help?Marwa
Marmar1870
Hi Allen,
Please explain what to delete exactly, shall i delete the offline address book? in the Public Folder Management Console?
Marwa
Allen Song
Whether all the new users have this issue or just one new user?
Please use ADSI Edit tool to locate the problematic new user, then right click it and select the Properties, find the showInAddressBook attribute, then post the values here.
Allen
Allen Song
Marmar1870
Hi Allen,
Only new user is not shown in GAL when i use the outlook only but they are correctly shown in OWA , & also when i access company directory from my mobile , the new users is listed in all contacts & all users in outlook
Marwa
Allen Song
For the new users, are they created on the new mailbox database? Did you associate the mailbox database with the Default Offline Address Book?
You can check the msExchUserOAB attribute on the Database. Additionally, I suspect this issue is related to the OAB issue. Please improve the Diagnostic logging of the OAB, then update the Default Offline Address Book, then check the event log.
Allen
Allen Song
Marmar1870
Hi Allen,
I have checked the database & for some reason i find the OAB is empty so i fixed & update the OAB , im not sure if i have to wait somtimes before outlook address book is updated or not.
Marwa
Marmar1870
Hi Allen,
It has been 4 hours now & nothing changed , the database is associated to the default address book , the offine address bokk has been updated, i have absloutely no errors in event log , & still new users not shown in outlook GAL but is shown in OWA & shown in outlook via all contacts & all users.....any help?
Marwa
Allen Song
Be default, the OAB is updated daily at 5:00 AM, you can check the Schedule under the Default Offline Address Book.
Now please first delete the OAB files under the shared OAB folder in Mailbox server, then delete the OAB files in the CAS, next update the Default Address Book, check the OAB files are generated under the Shared OAB folder, and restart the Microsoft Exchange File Distribution service, the OAB files will be copied to CAS from the Mailbox server.
Restart IIS, and check this issue.
Allen
Allen Song
Joe Tam
Dear Marmar,
You can consider to enable registry key for further checking, please remember to turn it off after diagnostic.
-Select My Computer\HKEY_Local_Machine\System\CurrentControlSet\Services\MSExchangeSA\Diagnostics\”13 OAL Generator”, change the value from “0” (Disable) to “7” Full diagnostic.
Regards,
Joe
Marmar1870
Hi All,
I guess i have somthing new i have run this command
get-oabvirtualdirectory | ft internalurl
& i got this answer
https://mydomain/oab
it was not my internal domain , it was my external domain
when i tried to browse to this URL i got this error
HTTP Error 500.19 - Internal Server Error The requested page cannot be accessed because the related configuration data for the page is invalid.
Error Details
Module IIS Web Core Notification BeginRequest Handler Not yet determined Error Code 0x80070005 Config Error Cannot read configuration file due to insufficient permissions Config File \\?\C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\OAB\web.config
Requested URL https://myip:443/OAB Physical Path C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\OAB Logon Method Not yet determined Logon User
Not yet determined
how can i fix that?
Regards
Marwa
Marmar1870
I fixed the internal URL
but still unable to browse & when i try to download OAB on outlook i got this message
" Task " Microsoft Exchange " reported error (0x8004010f): The operation failed . An object cannot be found"
is this mean the OAB is lost?
if so how can i update without errors?
Marwa
Allen Song
Please press Ctrl+right click Outlook icon in System Tray, uncheck both of the Guessmart options, click Test button, could you get the OAB URL under Results Tab?
Additionally, please run test-Outlookwebservices |fl command in EMS, then post the results here.
Allen
Allen Song
G
Gulab Mallah
Okay, its been very long time you guys have been working on this issue. Let fix it by trying this
*One more thing is, make sure that on the CAS server you don't have Web.Config file in the .LZX file location
If above doesn't work follow below
Create the new OAB and associate with Mailbox Database and Point the new OAB to the Database.
Restart the MS Exchange FDS and System Attendant Service.
Update the New OAB
Check if the LZX files are generated in OAB shared folder on Mailbox Server and CAS Server
I am sure it should fix the issue
Gulab | Skype: gulab.mallah
Marmar1870
Hi.
The result for the test-outlook web services is :
VERBOSE: Connecting to Exchange2010.Egytrav.local
VERBOSE: Connected to Exchange2010.Egytrav.local.
[PS] C:\Windows\system32>test-Outlookwebservices |fl
RunspaceId : 6bf1370e-5055-4d96-9244-e58a89d4a645
Type : Information
Message : A valid Autodiscover service connection point was found. The Autodiscover URL on this object is
change.egytrav.com/autodiscover/autodiscover.xml.
Type : Information
Message : Contacted the Autodiscover service at
Type : Information
Message : [EXCH] The OAB is configured for this user in the AutoDiscover response received from
Type : Information
Message : [EXCH] The UM is configured for this user in the AutoDiscover response received from
Type : Information
Message : [EXPR] The AS is configured for this user in the AutoDiscover response received from
Type : Information
Message : [EXPR] The OAB is configured for this user in the AutoDiscover response received from
Type : Information
Message : [EXPR] The UM is configured for this user in the AutoDiscover response received from
Type : Success
Message : Autodiscover was tested successfully.
Type : Information
Type : Information
Message : [EXCH] The AS is configured for this user in the AutoDiscover response received from
https://Exchange2010.Egytrav.local:443/autodiscover/autodiscover.xml
https://exchange.egytrav.com/ews/exchange.asmx
> The elapsed time was 106 milliseconds.
> The elapsed time was 771 milliseconds.
https://exchange.egytrav.com/EWS/Exchange.asmx
> The elapsed time was 93 milliseconds.
> The elapsed time was 25 milliseconds.
https://exchange2010.egytrav.local/ews/exchange.asmx
> The elapsed time was 51 milliseconds.
https://exchange.egytrav.com/rpc
received the error The remote server returned an error: (503) Server Unavailable.
> Elapsed time was 56 milliseconds.
https://exchange2010.egytrav.local/rpc
> Elapsed time was 19 milliseconds.
https://Exchange2010.Egytrav.local:443/autodiscover/autodiscover.xmlhttps://exchange.egythttps://exchange.egyhttps://exchange.egythttps://exchange.egythttps://exchange.egyhttps://exchange.egytrav.com/autodiscover/autodiscover.xml
https://exchange.egythttps://exMarwa
Marmar1870
is there an update regarding .net that affect OOA , OAB & free-busy information?
coz i guess this is what happened to me but i have no idea what to do, shall i simply uninstall the update?
it has been installed on 1/11/2010
plz help
will everything back to normal or do i have to adjust things manually?
Marwa
Allen Song
Sorry for the delay response.
On your CAS server goto C:\Program Files\Microsoft\Exchange Server\Client Access\OAB" folder and and right-click web.config and open properties->Security tab and give Authenticated Users both the read and read-and-execute permissions. Run iisreset /noforce on the CAS server and then check the issue.
Allen
Allen Song
