Problem removing a mailbox server from a DAG.
mjolinor
Environment: We've got an Exchange 2010 installation. We have two mailbox servers in our primary data site and two in our backup site. A temporary mailbox server in the backup site got added to the DAG, and we'd like to remove it (we're done with it, and having more servers in the backup site than the primary site causes failover issues). When I try to remove it, I get this error:
[2010-11-15T19:21:59] WriteError! Exception = Microsoft.Exchange.Management.Tasks.DagTaskProblemChangingQuorumException: There was a problem changing the quorum model for database availability group CTSDAG. Error: An Active Manager operation failed. Error: An error occurred while attempting a cluster operation. Error: Cluster API '" GetClusterQuorumResource() failed with 0x138f. Error: The cluster resource could not be found" ' failed.
Biggle fruitless. Anybody seen this before?
[string](0..33|%{[char][int](46+(" 686552495351636652556262185355647068516270555358646562655775 0645570" ).substring(($_*2),2))})-replace " "
K
Kevin Ca
Are you still running into this issue?
I have heard this problem come through only a couple of times, but in a couple of occassions the MaxQuorumLogSize value was incorrect.
HKLM\Cluster\Quorum\MaxQuorumLogSize
I believe a DAG with an odd number should be 0, and a dag with even number should be 0x400 (1024 decimal).
Another indicator of this value being incorrect is an error when opening the failover cluster manager. Are you able to open this on all nodes?
Kevin Ca
Kevin Ca
V Outlook problem after removing avast Using Outlook 1
B Problem with import Excel BCM (Business Contact Manager) 1
chupacabra Problem with IMAP .pst file Using Outlook 13
deonholt Address Book problem and created new profile ... Using Outlook 1
X Problem Transferring Subset of Outlook 2013 Contacts to iPad/iPhone Using Outlook 5
