Exchange 2010 SP1 RU1 - Get-PublicFolderDatabase bug / documentation issue?
K
Karl Mitschke
Example two in Get-Help Get-PublicFolderDatabase -Examples claims that you cn get a PF database by Server\DB.
In Exchange 2007, I can.
In Exchange 2010 SP1, I cannot.
I receive the error:
Cannot process argument transformation on parameter 'Identity'. Cannot convert value " Server\PfDB" to type " Microsoft.Exchange.Configuration.Tasks.DatabaseIdParameter" . Error: " 'Server\PfDB' is not a valid value for the identity.
Is this a bug, or an error in the documentation? In other wors, did the Exchange team remove this on purpose?
Get-PublicFolderDatabase without patrameters DOES show my DB and Server as being correct
Karl
http://unlockpowershell.wordpress.com
-join(" 6B61726C6D69747363686B65406D742E6E6574" -split" (?<=\G.{2})" ,19|%{[char][int]" 0x$_" })
Brian Day MCITP
For PF DB on 2010 you shouldn't need the Server\ portion since DB names are unique throughout the org.Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
K
Karl Mitschke
Brian;
Sure, but the documentations says you can use Server\DB
I just want to know if it's a BUG that you cannot, or a Documentation error.
Saying " Do it another way" doesn't really answer the question ;)
Karl
Brian Day MCITP
Brian;
Karl
There are a few places where Server\DB or Server\SG\DB is still necessary for legacy interaction, but any command being issued aganst a 2010 server should only need the DB name unless you're working with Database Copy cmdlets, which may need DBName\ServerWithCopy. So while the documentation is probably technically correct, it may benefit by adding a couple more details. The key is all DB names must be unique in the org with 2010.Microsoft Premier Field Engineer, Exchange
K
Karl Mitschke
Brian;
I think we are saying the same thing, in different words.
I agree that you don't need the Server\DB syntax.
Certainally, the name must be unique within the org. New-PublicFolderDatabase documentation agrees with us on that.
I just want the documentation on Get-PublicFolderDatabase to be correct.
Get-Help Get-PublicFolderDatabase -Detailed
<snip>
-Identity <DatabaseIdParameter>
The Identity parameter specifies a public folder database. You can use the following values:
* GUID
* Distinguished name (DN)
* Server\database name
* Database name
If you don't specify the server name, the cmdlet searches for databases on the local server. If you have multip
le databases with the same name, the cmdlet retrieves all databases with the same name in the specified scope.
<snip>
http://technet.microsoft.com/en-us/library/aa998827.aspx shows the same thing.
Karl
Brian Day MCITP
All I'm saying is that I think it is correct, depending on what server you're executing it against. :) I agree it could use a clarifying statement.Microsoft Premier Field Engineer, Exchange
K
Karl Mitschke
From Exchange 2010 to Exchange 2007 I need Server\SG\DB
I cannot find any instance in 2010 where Server\DB works.
I will just mark it down as a " Feature"
K Backup recommendation for Exchange 2010 SP1 on Hyperv 2008 R2 Exchange Server Administration 3
F AD RMS with Exchange 2010 SP1 Exchange Server Administration 4
D Exchange Server 2010 SP1 Hosted Mode, service@ mailbox creation Exchange Server Administration 1
I Event ID 2937 after update to Exchange 2010 SP1 ArbitrationMailbox Exchange Server Administration 4
M Exchange 2010 SP1 Hosted Mode - how to move mailbox from old organization? Exchange Server Administration 1
P Journaling deployment Exchange 2010 SP1 RU1 Exchange Server Administration 1
I Event ID 2937 after update to Exchange 2010 SP1 Exchange Server Administration 8
G Exchange 2010 upgrade with SP1, language pack issue Exchange Server Administration 5
R Dynamic DNS update requirement for Exchange 2010 (SP1 RU1) on server 2008 r2 Exchange Server Administration 8
A NetBackup 7.0 configuration for Exchange 2010 SP1 Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
K Question about Exchange 2010 SP1 RU2 update Exchange Server Administration 3
J Exchange 2010 SP1 fails at Mailbox Error Unable to load exrpc32.dll Exchange Server Administration 4
D Exchange 2010 SP1 Policy to Delete mail in deleted items older than 30 days Exchange Server Administration 2
à Validating build of Exchange 2010 SP1 Exchange Server Administration 1
D Exchange 2010 SP1 topology prep error Exchange Server Administration 3
I Exchange 2010 sp1 Address Book service won't start after static RPC port reconfiguration Exchange Server Administration 2
D Installing SP1 for Exchange 2010 Exchange Server Administration 2
B Blank email list views on Outlook 2010 / 2007 with Exchange 2010 SP1 (on Citrix and Desktops) Using Outlook 7
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
P Mircrosoft Exchange 2010 SP1 Email Purge Exchange Server Administration 2
P Error 4999 after Exchange 2010 SP1 - No BES server Exchange Server Administration 12
D Upgraded to Exchange 2010 SP1 and now random Outlook clients are requesting authentication Exchange Server Administration 1
Q Don't have right permissions to assign "send as" rights in Exchange 2010 SP1 Exchange Server Administration 7
M Exchange 2010 SP1 Event id 9040 : Unable to save watermarks Exchange Server Administration 5
C Exchange 2010 SP1 "RPC can't be started because of the EMSMDB interface is already registered by Exchange Server Administration 4
N Failed Exchange 2010 SP1 Installation PowerShell "unauthorized operation" Exchange Server Administration 2
L Does Exchange 2010 SP1 update any Schema objects Exchange Server Administration 2
T After updating Exchange 2010 from RTM to SP1, OWA clients cannot move or delete emails Using Outlook 4
P Exchange 2010 SP1 Cross Site CAS connection disable Exchange Server Administration 2
A Exchange 2010 SP1 RU1 Calendar Retention Exchange Server Administration 1
M Do Database Storage Limits in Exchange 2010 SP1 affect Archive mailboxes? Exchange Server Administration 5
L Exchange 2010 SP1 Pre-Req error Exchange Server Administration 2
W Exchange 2010 SP1 Install- Required HotFixes Exchange Server Administration 3
N Second Mailbox, Mails stuck in Outbox Outlook 2010, Exchange 2010 SP1 Using Outlook 8
S Determine Managed Folder Policy for Mailbox in Powershell Exchange 2010 SP1 Exchange Server Administration 4
C Installing Exchange 2010 SP1 in a Sub domain... Exchange Server Administration 5
D Ms Exchange 2010 - Sp1 Upgrade at Prerequisites on Hub Transport Role Exchange Server Administration 8
C Managed Folder does not show up in Outlook in Exchange 2010 Sp1 Rollup 1 Exchange Server Administration 3
J After Applying Exchange 2010 Sp1 Rollup the Build numbers in EMC remain unchanged 14.1.218.15 Exchange Server Administration 1
M how to upgrade exchange 2010 to exchange 2010 sp1 Exchange Server Administration 2
J Mailbox Export Import issue on Exchange 2010 SP1 Exchange Server Administration 4
