CAS/MBX reboot best practices.
Sam Booka
Hi, I have to reboot my MBX and CAS servers tonight for more memory. We have two CAS servers in NLB and two MBXs in DAG.
Is there a best practice to rebooting the servers? Drain stop on the CAS server? Move active MBX copies before rebooting? Or let the shutdown process take its course.
Drew
Sembee [MVP]
If you have CAS in NLB, then those can just be rebooted one after the other, it will let you confirm the NLB works correctly. No need to do anything special with the CAS.
For the DAG, reboot the server with the passive databases on it, then switch the active database to that server and reboot the other one.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
Justin.King
Possbily silly, but I assume you are adding memory? If not, remeber that as 64bit systems Exchange _will_ consume all the memory it can, and it's not a memoy leak or anything negative to see it eating up all your memroy.
I only bring this up because I get asked this a lot for whatever reason.
Steve Goodman
Just to add, you can use StartDagServerMaintenance.ps1 and StopDagServerMaintenance.ps1 (more info ) to move active mailbox copies whilst performing maintenance. Are any of those CAS running the FSW? If so, you may want to do this server last.
Steve
Steve Goodman
Brian Day MCITP
Depending on how invasive you want to be to the users, you can consider drainstopping the CAS server before rebooting it.Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
Brian Day MCITP
Document any DBs that were activation blocked before running StartDagServerMaintenance,ps1 because they'll no longer be blocked after you run those scripts.Microsoft Premier Field Engineer, Exchange
Sam Booka
Ok.. I will look at the scripts. I am doing this off hours so as not to be a PITA to the users.
I dont think I have anything activation blocked.
Yes.. we have 4GB ram on both CAS and MBX servers. No issues yet but bumping to 8 before it becomes an issue. I have noticed that with 25 or 250 users memory usage has not changed. Thanks for the heads up tho :)
The CAS with the FSW is not getting touched yet. We need to free up a little more memory on that esx host.
Drew
Sam Booka
I had one DB I couldnt fail over. Since there was no one in it (just test accounts) I rebooted the server and it DID mount successfully on the passive node. Funny that. Otherwise everthing went fine.
Drew
P CAS-Transport-MBX on Single Server Exchange Server Administration 2
C Watson Error on CAS Exchange Server Administration 1
S Exchange CAS server OAB directory not showing web.config file Exchange Server Administration 3
T RBAC Error on UM/CAS Servers Exchange Server Administration 2
R FQDN of Exchange CAS servers not in SSL cert Exchange Server Administration 2
D CAS Design Question Exchange Server Administration 4
D Exchange 2010 CAS at 2 different Sites Exchange Server Administration 2
T Cas server uninstall failed... Now how to reinstall? Exchange Server Administration 4
S Any system impact if change exchange 2010 CAS/HUB and Mailbox server IP address Exchange Server Administration 1
B Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 15
M Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 2
I Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 4
M CAS Issue: OWA/Outlook remote users cannot login Exchange Server Administration 1
C CAS Proxy problem Exchange Server Administration 5
K Exchange 2010 OWA redirection between 2 CAS Servers Exchange Server Administration 5
S exchange 2010 cas memory usage Exchange Server Administration 2
P Exchange 2010 SP1 Cross Site CAS connection disable Exchange Server Administration 2
H Outlook 2007 periodically disconnects from Exchange 2010 CAS - OWA works Using Outlook 4
C CAS Connections overview Exchange Server Administration 9
E error cas Exchange Server Administration 2
B CAS certificate question Exchange Server Administration 3
F Error on CAS Exchange Server Administration 3
J Exchange 2010 CAS Server OWA Redirection to Exchange 2003 Fail Exchange Server Administration 4
H Is possible to have exchange 2007 CAS point to the exchange 2010 CAS? Exchange Server Administration 2
2 muliptle external domains to access one CAS server Exchange Server Administration 4
