Trouble removing old 2000 Exchange
Bala Osman
Hello.
i have this isuue removing exchange 2000, i did used edsiedit and i found there is server in the first orgnization servers containers, now what should i do?
only remove it from there and that it? or there something farther??
waiting your reply
thanks
alashcroft
Can you give more details of what you have done so far.
Does the Exchange 2000 server still exist? Is your exchange org now E2010? Did you replicate public folders etc?
L
lAdK
if the server is still there the best you can do is put the cd of exchange and run uninstall
if the server is gone a long time ago then you will need to use adsiedit to remove it
run adsiedit.msc and connect to the configuration partition
services -> ms exchange -> organization -> administrative groups -> first admin group (or whatever the name is) -> servers and find the orphan server and delete it
make sure to delete ONLY the orphan the server since adsiedit is a dangerous tool to play with
lAdK
blog | twitter
Bala Osman
Hello All.
after i cleaned the orphan server, it's i can installed exchange 2010 fine.
thanks
B Trouble removing old 2000 Exchange Exchange Server Administration 5
G Trouble with Office 365/2016 Using Outlook 3
M Trouble downloading Outlook on an Android phone Using Outlook 4
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
U Trouble migrating Contacts (2002) to People (2013) Using Outlook 3
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
M Trouble Importing folders from Outlook 2007 to Outlook 2013 Using Outlook 12
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
T Outlook 2007 - trouble with alphabetizing when titles are used (ie - Mr.) Using Outlook 0
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
B Trouble Adding @Outlook.com Email Accounts Using Outlook 3
K Trouble converting the ANSI PST to a Unicode PST Using Outlook 4
U Trouble for sharing Calendar Using Outlook 3
S Trouble setting up Outlook Connector to sync with windows live Using Outlook.com accounts in Outlook 3
N Trouble importing calender information from iPhone into OutLook 2010 Using Outlook 1
J TROUBLE SENDING EMAIL FROM OUTLOOK, NO PROBLEM RECIEVING WHEN WORKING FROM OUT OF TOWN Using Outlook 1
D Trouble using Hotmail with Outlook connector, cannot receive mails Using Outlook 1
T Outlook 2010 and new mail sound trouble Using Outlook 2
B Having trouble with an Outlook Profile. Can I uninstall Outlook 2010 and install it again? Using Outlook 11
D Trouble downloading Calendar Printing Assistant for Outlook 2010 Using Outlook 2
B Trouble installing office because of outlook and BCM? Using Outlook 1
B haveing trouble with initial install of exchange 2010 Exchange Server Administration 6
M im having trouble going from one mail server to another on my computer Using Outlook 1
J trouble importing Office 2003 contact data (activities,etc.) using .pst file export & import to a se Using Outlook 1
D trouble sending e-mail from home to work Using Outlook 1
J I am having trouble opening opening links with in an e-mail. Using Outlook 2
M I am having trouble sending my e-mails in Outlook 2007. I can receive them, but not send. My internet provider says they can't help me. What to do? Using Outlook 6
V Outlook 2007 and mobile devices having trouble with Exchange 2007 Using Outlook 2
L mail merge trouble 2003 - sends only 2 out of 150+ entries in data file Using Outlook 1
M Exchange 2010 SP1 install trouble. Exchange Server Administration 10
V Trouble using RBAC to change passwords and distribution groups Exchange Server Administration 16
T Trouble with creating database BCM (Business Contact Manager) 1
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
K Trouble using SaveAs Outlook VBA and Custom Forms 3
M trouble connection to remote database BCM (Business Contact Manager) 1
R Outlook is NOT removing attachments. Using Outlook 4
B Removing Recipients from an automatic response Outlook VBA and Custom Forms 2
O How to paste website content using a specific font and removing URLs Using Outlook 2
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
A Removing illegal characters Outlook VBA and Custom Forms 2
D 'removing' an e-mail folder Using Outlook 2
