ECP and RBAC aren't working
Master Yoyo
ECP - I get redirected to form-based authentication page whenever i clicked on the options link. I put in the correct credentials and still get the same page
RBAC - same behavior
I tried to set both OWA and ECP the same authentication but when I do a " iisreset /noforce" I'd get reset failed (2147943453, 8007041d) and so the setting just doesn't stick.
any suggestions?
I'm running Exchange 2010 SP1 on Windows 2008
Master Yoyo
Thanks for your suggestion Christian. I got owa,ecp and activesync reset but I still get the form-based credentials page. I now see both using form-based authentication. What else can I try?
C
Christian Weihs
Hi Master Yoyo,
Can you check if all service are running: test-exchangeservices
Are all prerequisites installed?:
Add-WindowsFeature NET-Framework,RSAT-ADDS,
Web-Server,Web-Basic-Auth,Web-Windows-Auth,
Web-Metabase,Web-Net-Ext,Web-Lgcy-Mgmt-Console,
WAS-Process-Model,RSAT-Web-Server,Web-ISAPI-Ext,
Web-Digest-Auth,Web-Dyn-Compression,NET-HTTP-Activation,RPC-Over-HTTP-Proxy
-Restart
Do you have any error events at the eventlog? Same problem without ssl?
Best regards
Christian
Master Yoyo
Hello Christain,
I tried that but still not working. I don't see any related messages in the app log. Where else should I look for?
H Exchange 2013 ECP migration connects to crashed server Exchange Server Administration 0
S Outlook Web App ECP Session Timeout Exchange Server Administration 2
E How to disabled group management option from ECP and still allow the users to manage from Outlook Exchange Server Administration 2
B OWA ECP new-mailbox and change password feature Exchange Server Administration 5
T ECP App pool Exchange Server Administration 3
T Unable to edit Distribution Group membership via Outlook (works via ECP). Exchange Server Administration 7
M Error in Mail Tracking ECP Website - Mail Tracking not working with DefaultDomain not found Error Exchange Server Administration 13
M Exchange 2010 ECP sign out problem Exchange Server Administration 7
M Error messeage in Exchange 2010 SP! ECP Panel (Message Tracking) Using Outlook 3
M Create corresponding ECP Exchange Server Administration 5
S 3 things broken, apparently related: EMC, EMS and ECP Exchange Server Administration 14
K Can't open "Manage Voice Mail" ECP page after enabling UM for a user Exchange Server Administration 9
K Exchange 2010 ECP Reports - search for emails from external recepient get 'Object Reference not set to an instance of an object' error Exchange Server Administration 4
A External Access to ECP Exchange Server Administration 11
E Exchange 2010 ECP "the server method 'getlist' failed" Exchange Server Administration 5
C Do you need a mailbox or be mail-enabled to access ECP? Exchange Server Administration 8
R OWA + ECP First login slow Exchange Server Administration 8
C Can't recreate Exchange 2010 ecp Virtual Directory Exchange Server Administration 20
B Re: how to allow users to edit Title and Department in ECP/OWA? Exchange Server Administration 31
N RBAC for Full Access & Send-As Exchange Server Administration 3
T RBAC Error on UM/CAS Servers Exchange Server Administration 2
S RBAC for Mail quota increase Exchange Server Administration 2
A RBAC authorization returns Access Denied for user Exchange Server Administration 5
F Re: Restricting Database Access Using RBAC Exchange Server Administration 4
B Re: Restricting Database Access Using RBAC Exchange Server Administration 3
C RBAC Cross Domain issues Exchange Server Administration 8
L Canot access RBAC as administrator Exchange Server Administration 18
R 500 internal server error - Role based Access Control (RBAC) User Editor Exchange Server Administration 2
J Advanced RBAC - restricting delegate configuration Exchange Server Administration 1
C Custom RBAC question Exchange Server Administration 3
D Assign rbac to specific group does not take affect. Exchange Server Administration 15
A EMC - Launching RBAC Editor getting errors Exchange Server Administration 7
V Trouble using RBAC to change passwords and distribution groups Exchange Server Administration 16
Z Need help with an RBAC role Exchange Server Administration 14
I RBAC Authentication error - Remote EMC not able to access Exchange Organization Exchange Server Administration 13
I Different users connected to an IMAP email aren't syncing with each other Using Outlook 5
R Any idea why my category colours aren't showing in my calendar? Using Outlook 0
S Reminders aren't showing up Using Outlook 3
A Major Server Crash - Now Public Calendar Categories Aren't Working! Using Outlook 1
P where can i store hyper links so that they aren't detected as a threat to the computer Using Outlook 2
M Rules applied that aren't current Rules Using Outlook 2
C Outlook 2010 Trial Is Up and Now 2007 Address Books Aren't Connecting to Contacts Using Outlook 24
F Messages take long to appear, rules (here they come again) don't work, sent messages aren't saved Using Outlook 8
J Why are some rule names inclosed in quotation marks and others aren't? Using Outlook 1
N Outlook 2010. Why aren't my emails saved? Using Outlook 2
V Journal Folders aren't displaying? Using Outlook 1
J Why aren't the emails I send going into a sent folder? Where are yesterday's emails as I don't see t Using Outlook 2
S Exchange 2010 complaining about EX 2007 Receive Connectors being 'Inconsistent' (they aren't!!) Exchange Server Administration 6
J Outlook messages aren't indexing in Search; "Index messages in these data files" is blank Using Outlook 17
B Why aren't my Calendar reminders popping up on my screen? Using Outlook.com accounts in Outlook 3
