Exchange 2010 Automated Installations
G
Gunner999
My company is looking at deploying a large Exchange 2010 deployment from scratch (new installs) in a virutal environment. That means we are looking for several options to help us use templates to deploy the various Exchange roles (CAS, DAG, HUB) quickly and without manual installation every time we want to stand up a new server.
I have searched the web but have not been able to find any information on any of the following topics. I'm hoping someone can point me to the Microsoft documentation that may cover these topics or issues.
Below are the topics I have been looking for information on.
1) Install Exchange 2010 and deploy a virtual machine via a template using Sysprep.
I find mixed information on this at best, but no offical policy from Microsoft....can anyone point me to Microsoft KB or support statement that says sysprep of Exchange is or isn't supported? Also, I am looking for specifics on sysprep of CAS vs HUB vs Mailbox/DAG server. Maybe the CAS supports sysprep and the others don't, vice versa, etc?
2) Automating installations of Exchange 2010 to new server. Hopefully, this would be with no user interactions.
3) Best practices or automating Exchange 2010 installations.
Any other ideas and suggests are welcome, but i am looking for information on how the above topics specifically.
Sembee [MVP]
You can't sysprep a server with Exchange installed because of the integration of Exchange and the AD. Doesn't matter on the role.
Therefore the most you can do is install a machine with all of the pre-requisites, then sysprep that, then install Exchange once the machine has been added to the domain.
Installation automation is pretty easy with the command line, and once the installation is complete, use PowerShell commands to customise the installation. All of the commands are documented on Technet.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
G
Gunner999
Sembee
Thanks for the reply, but i am still looking for links to offical Microsoft statements about sysprep and Exchange.
Also, do you have any links to online references from Microsoft or 3rd Party for automating installations? Its great you know its easy, but i don't. Clearly you have some experience, can you share more technical details, please?
Like can i save settings from a wizard to an answer file or have it create the install script? If so, explain how, or provide a reference.
Gotta yas, and common mistakes, etc. Some detail would be nice, i am starting from scratch here.
Do you have any examples of using powershell to customise the installation? Links to these would be nice. Examples of common post installation configuration tasks most administrators may do with powershell, would be nice. No since re-inventing the wheel...
G
Gunner999
Wow, not many replies on this. All-in-all i say the unattended installation is NOT EASY, given the clear lack of information available. I'm a little surprised that there is so little help on this topic beyond the command line switches given here http://technet.microsoft.com/en-us/library/aa997281.aspx
Your pretty much left with going through one of the Technet installation template documents and converting that over to installation scripts. As these templates point out you need to automate more than just the installation, you most likely need to automate alot of configuration as well, otherwise whats the point....at least in my case.
http://technet.microsoft.com/en-us/library/ff622322.aspx
If someone else has any more information on how to automate some of the configuration tasks i would appreciate additional information, but this is a real pain....don't be fooled by these MVP's claiming its easy.
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
R Create a contacts list on Exchange 2010 Exchange Server Administration 10
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
R Sharing Exchange 2010 calendars with people outisde our organization Exchange Server Administration 17
A Exchange 2010 Outlook 2010 and Local Failures sync issue Exchange Server Administration 5
B Exchange 2010 / Outlook 2010 - Group Folder issues Exchange Server Administration 6
U Exchange 2010 & mailbox database Quotas Exchange Server Administration 1
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
C Outlook/Exchange 2010 Recover Deleted Items to original folder Using Outlook 2
D large mailbox question using 2010 on exchange 2k3 Exchange Server Administration 2
R Change Outlook 2010 Exchange server address via registry or script Using Outlook 5
R Can't close Personal Folders after switching to Exchange 2010 Using Outlook 2
