Exchange 2010 OWA redirection between 2 CAS Servers
K
Kndurai
I need some assistance, we have two AD sites, each site have separate OWA site. (Each site we have 2 CAS servers and 2 Hub Servers and mailbox Servers) when one site users login into Their Own Wep app site it is working fine. but i would like to simplfiy that, if any user choosing wrong site it should automatically redirect to other site Outlook web app.
like http://webmail1.domain.com if the user entering the credentials (actually it should redirect to http://webmail2.domain.com)
How can i achive this. i know for Exchange 2003 we can do legacy.domain.com redirection. but Exchange 2010 how it could be.
anyone can assist this...it will be great
Tom Vanopoulos
In Exchange 2010 and also 2007 if there are multiple AD sites the easiest approach would be to configure CAS to CAS proxy. Take a look at the following article.
In this type of scenario, you CAS sitting in AD 1 and you have a CAS + MBX in AD2. External users would hit CAS in AD1 and the request would be proxied to the CAS in AD2 where the mailbox resides in that site.
http://technet.microsoft.com/en-us/library/bb310763.aspx
MCITP: Enterprise Messaging Administrator 2007/2010 | MCITP: Server Administrator | MCTS: Windows Server 2008 Applications Infrastructure, Configuring | MCP | MCDST
AndyD_ [MVP]
If both of these CAS are internet-facing and the externalURLs are populated, the end-user will be prompted with the URL of the better CAS to use. Is that not acceptable?
K
Kndurai
Hi Tom & Andy,
Thanks for the reply. As Andy mentioned here, URL is prompting of the better CAS Web app to use,
The requirement is now to redirect automatically to other CAS web app if they are using Another Site users. I am getting proper Response from both Web app to use the site name itself.
Both site internet-face. can we enable proxying between these site vice versa?
Brian Day MCITP
Only if you remove the ExternalURL value from both sides, but that will also require creating an additional OWA vDir on each CAS server and enabling WIA for Kerberos to work between the CAS. It also breaks the OWA URL feature in Backstage of Outlook 2010. It isn't a suggested configuration because cross-site RPC connections are more expensive than just redirecting the user and having them learn the proper URL to use. Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
My posts are provided “AS IS” with no guarantees, no warranties, and they confer no rights.
S Signature size limit for OWA / Exchange 2010 Exchange Server Administration 10
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
M Exchange OWA 2010 acting quirky. Exchange Server Administration 2
M Integrated OCS with Exchange 2010 OWA didn't work over ISA server Exchange Server Administration 4
M Exchange 2010 OWA '403 Access Denied' Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
F Exchange 2010 - OWA 15 min auto logoff Exchange Server Administration 1
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
à owa and powershell take times on exchange 2010 Exchange Server Administration 8
S Exchange 2010 OWA Search only returns 2 days worth Using Outlook 2
A Exchange 2007 <-> 2010 OWA not working together redirecting problem Exchange Server Administration 1
D Is there a way to turn off "group by conversation" by default in OWA Exchange 2010? Using Outlook 2
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
T Exchange 2010: attachments are not visible in outlook, but visible in OWA Using Outlook 1
Z Exchange 2007 Transitioning to Exchange 2010 SP 1, and OWA User Redirect or Proxying Exchange Server Administration 1
S Exchange 2010 - owa/auth.owa Bad Request Exchange Server Administration 3
Y public calendar using OWA on exchange 2010 Exchange Server Administration 7
T After updating Exchange 2010 from RTM to SP1, OWA clients cannot move or delete emails Using Outlook 4
S Exchange 2010 owa https not working Exchange Server Administration 5
J Exchange 2010 / 2003 OWA Problem Exchange Server Administration 2
B 500 error after authenticating in OWA - Exchange 2010 Using Outlook 1
S Outbox not displayed in Exchange 2010 OWA Exchange Server Administration 5
H Exchange 2010 - Blank e-mail body in Outlook but typically viewable in OWA Exchange Server Administration 6
C Manage OWA access during the migration from Exchange 2003 to Exchange 2010 (Resource Forest) Exchange Server Administration 4
H Outlook 2007 periodically disconnects from Exchange 2010 CAS - OWA works Using Outlook 4
S Exchange 2010 OWA error 404 with IE 8 Exchange Server Administration 1
K Outlook 2010 on Exchange - 'Sent Items' box always empty on client, but populated in OWA Using Outlook 5
A Exchange 2010 OWA Document Access Exchange Server Administration 3
M block individual IP to Exchange 2010 owa Exchange Server Administration 3
E How to set Kerberos Authentication for OWA on Exchange 2010. Using Outlook 2
J "Clip" icon appear in Microsoft Outlook 2010 / Exchange 2007 OWA Message, but no attachment inside Using Outlook 4
B Exchange 2010 OWA not working on client- Ex2k7 worked Using Outlook 4
J Exchange 2010 CAS Server OWA Redirection to Exchange 2003 Fail Exchange Server Administration 4
S custom look for OWA in exchange 2010 Exchange Server Administration 4
B Exchange 2010 Migration - OWA not working Exchange Server Administration 2
K Some user cannot delete email in OWA Exchange 2010 SP1 Exchange Server Administration 5
R OWA ISSUE Exchange 2010 co-existance with Exchange 2003 Exchange Server Administration 3
M use owa rtm theme in exchange 2010 sp1 ? Exchange Server Administration 5
M owa old theme from exchange 2010 rtm Using Outlook 1
T Exchange 2010 public folders cannot be opened from Outlook, but can from OWA Exchange Server Administration 2
L new install Exchange 2010 OWA web page not formatting correctly/unusable Exchange Server Administration 2
M Cannot Change the branding logo in exchange 2010 SP1 owa default theme Exchange Server Administration 6
