Exchange 2010 owa https not working
stonecold31666
After installing a ssl certificate on exchange 2010 we can not use https. I can go to the iis owa virtual directory and remove the ssl required check box and connect via http fine.
Windows 2008 rd and exchange 2010Stonecold31666
Brian Day MCITP
Did you use the Cert Wizard, EMS, or Certificate Manager to get the cert in?
Did you assign the cert to IIS with Enable-ExchangeCertificate if you didn't use the cert wizard? It would look something like..
Enable-ExchangeCertificate -Thumbprint <Thumbprint of the cert found with Get-ExchangeCertificate> -Services IIS
Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
stonecold31666
i used the exchange management console. Now my cert doesn't even show in the console.
Stonecold31666
stonecold31666
i get
The certificate with thumbprint " Thumbprint" was found but is not valid for use with Exchan
ge Server (reason: PrivateKeyMissing).
+ CategoryInfo : NotSpecified: :)) [Enable-ExchangeCertificate], InvalidOperationException
+ FullyQualifiedErrorId : 78EFD023,Microsoft.Exchange.Management.SystemConfigurationTasks.EnableExchangeCertificat
e
Stonecold31666
stonecold31666
ok, i got the cert issue fixed and added back in and owa works. now problem on the oulook 2010 client. I get and alert saying " the name on the security certificate is invalid or does not match the name of the site"
It says its from a trusted authority and the the date is valid
Stonecold31666
E
Evan Liu
Any updates on this issue?
For the error &ldquo;the name on the security certificate is invalid or does not match the name of the site&rdquo;. You can refer to this document:
Security warning when you start Outlook 2007 and then connect to a mailbox that is hosted on a server that is running Exchange Server 2007 or Exchange Server 2010: " The name of the security certificate is invalid or does not match the name of the site" ( although this is for Outlook 2007, I suggest you follow this to have a check)
http://support.microsoft.com/kb/940726
If the problem persists, please feel free to let me know and I will be glad to help.
Evan
S Signature size limit for OWA / Exchange 2010 Exchange Server Administration 10
M Exchange 2010 OWA Redirect with Authentication Across AD Site Exchange Server Administration 1
M Exchange OWA 2010 acting quirky. Exchange Server Administration 2
M Integrated OCS with Exchange 2010 OWA didn't work over ISA server Exchange Server Administration 4
M Exchange 2010 OWA '403 Access Denied' Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
F Exchange 2010 - OWA 15 min auto logoff Exchange Server Administration 1
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
à owa and powershell take times on exchange 2010 Exchange Server Administration 8
S Exchange 2010 OWA Search only returns 2 days worth Using Outlook 2
A Exchange 2007 <-> 2010 OWA not working together redirecting problem Exchange Server Administration 1
D Is there a way to turn off "group by conversation" by default in OWA Exchange 2010? Using Outlook 2
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
T Exchange 2010: attachments are not visible in outlook, but visible in OWA Using Outlook 1
Z Exchange 2007 Transitioning to Exchange 2010 SP 1, and OWA User Redirect or Proxying Exchange Server Administration 1
S Exchange 2010 - owa/auth.owa Bad Request Exchange Server Administration 3
Y public calendar using OWA on exchange 2010 Exchange Server Administration 7
T After updating Exchange 2010 from RTM to SP1, OWA clients cannot move or delete emails Using Outlook 4
J Exchange 2010 / 2003 OWA Problem Exchange Server Administration 2
B 500 error after authenticating in OWA - Exchange 2010 Using Outlook 1
S Outbox not displayed in Exchange 2010 OWA Exchange Server Administration 5
K Exchange 2010 OWA redirection between 2 CAS Servers Exchange Server Administration 5
H Exchange 2010 - Blank e-mail body in Outlook but typically viewable in OWA Exchange Server Administration 6
C Manage OWA access during the migration from Exchange 2003 to Exchange 2010 (Resource Forest) Exchange Server Administration 4
H Outlook 2007 periodically disconnects from Exchange 2010 CAS - OWA works Using Outlook 4
S Exchange 2010 OWA error 404 with IE 8 Exchange Server Administration 1
K Outlook 2010 on Exchange - 'Sent Items' box always empty on client, but populated in OWA Using Outlook 5
A Exchange 2010 OWA Document Access Exchange Server Administration 3
M block individual IP to Exchange 2010 owa Exchange Server Administration 3
E How to set Kerberos Authentication for OWA on Exchange 2010. Using Outlook 2
J "Clip" icon appear in Microsoft Outlook 2010 / Exchange 2007 OWA Message, but no attachment inside Using Outlook 4
B Exchange 2010 OWA not working on client- Ex2k7 worked Using Outlook 4
J Exchange 2010 CAS Server OWA Redirection to Exchange 2003 Fail Exchange Server Administration 4
S custom look for OWA in exchange 2010 Exchange Server Administration 4
B Exchange 2010 Migration - OWA not working Exchange Server Administration 2
K Some user cannot delete email in OWA Exchange 2010 SP1 Exchange Server Administration 5
R OWA ISSUE Exchange 2010 co-existance with Exchange 2003 Exchange Server Administration 3
M use owa rtm theme in exchange 2010 sp1 ? Exchange Server Administration 5
M owa old theme from exchange 2010 rtm Using Outlook 1
T Exchange 2010 public folders cannot be opened from Outlook, but can from OWA Exchange Server Administration 2
L new install Exchange 2010 OWA web page not formatting correctly/unusable Exchange Server Administration 2
M Cannot Change the branding logo in exchange 2010 SP1 owa default theme Exchange Server Administration 6
