New-MailboxImportRequest and Polish encoding problem
dominik_jeske
I have a problem using New-MailboxImportRequest command to import pst files form Exchange 2000 – imported mails are in wrong code page (my polish native signs like Ä…,Ä™,Å›… are display completely different). When I try to use Outlook to import data everything is ok. How can I fix this or maybe there it another way to import data from pts with right encoding?
F
Frank.Wang
Hi dominik,
Are all softwares same Polish language version?
pst file, Exchange 2010 SP1, windows 2008 OS and Outlook,and client OS.
dominik_jeske
Windows Server 2008, Exchange 2010 and all server stuff are in english language version and client OS and Outlook are polish versions - of course regional setting on servers are set to polish.
dominik_jeske
I had to use exterlan tool to convert pst to unicode - unfortunetly ms tools don't work with its own files :)
E Why does a Mailboximportrequest queue for at least 10 minutes before starting the import? Exchange Server Administration 1
R New-MailboxImportRequest fails.... Exchange Server Administration 4
V Remove-MailboxImportRequest fails because the mailbox was deleted. Exchange Server Administration 3
H Re: new-mailboximportrequest to archive ==> MapiExceptionNetworkError: Unable to save changes. Exchange Server Administration 5
H new-mailboximportrequest to archive ==> MapiExceptionNetworkError: Unable to save changes. Exchange Server Administration 0
M New-MailboxImportRequest: mailbox folders in different languages after import Exchange Server Administration 4
C new-mailboximportrequest Exchange Server Administration 8
C mailbox-export (exchange 2007) new-mailboximportrequest (exch2010 SP1) missing calendar re Exchange Server Administration 8
G New-MailboxImportRequest isn't finishing. Can't work out why. Exchange 2010 SP1 Exchange Server Administration 26
V New-MailboxImportRequest PST Subfolder issue Exchange Server Administration 0
T Can't use New-MailboxImportRequest. It just says its not recognize as name of cmd-let Exchange Server Administration 7
Commodore Wrapping and wrong encoding Using Outlook 2
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
V Encoding problem in subject line Using Outlook 0
E MIME encoding appearing in body of message Using Outlook 3
M I cannot read any foreign language mails in outlook 2010 (Encoding issue) Using Outlook 1
P How to disable unwanted encoding in Outlook 2010/Exchange 2007? Using Outlook 4
D Outlook 2010: problems with encoding Using Outlook 3
S Attatchments on my email opening up as encoding Using Outlook 4
B How to set encoding for all incoming mail. Using Outlook 2
