Setting permission on user Standard when mailbox is created
P
Peter747
we have granted the user 'Standard' on every mailbox toplevel the permission 'Folder Visible' and on the folder Calendar the permiisons 'Read and folder visible'. Reason for this was that every one should see the calenar items (read it (not only subject/locaton and only availablity was not enough!).
We have Exchange 2010 implemented and changed this setting after migration of all the mailboxes.
When we create a new mailbox the user 'Standerd' has not the correct settings. Is there a workaround so that every newly created mailbox gets the correct setting? (offcourse we can use powerscript afterwards; but that's not so handy and if some uses EMC directly it's not changed either).
Regards
Peter
Sembee [MVP]
There is no way I know of to do what you want through the GUI. For a custom provisioning task like this you would create your own script to create the account and set the relevant permissions and additional settings - that is kind of why everything was moved to command line - so that customisation is easily done.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
Marc2019 Setting up an Outlook Account on Mac Os 10.6.8 Outlook 2011 Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
B Setting rules Using Outlook 1
B Setting defaults Using Outlook 2
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
Jennifer Murphy Equations don't comply with style setting to left justify Using Outlook 0
J Setting default address book Using Outlook 0
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
Diane Poremsky Setting up an Outlook.com IMAP account New Slipstick.com Articles 0
Diane Poremsky Setting the default Country for Outlook Contacts New Slipstick.com Articles 0
Diane Poremsky Adjusting Outlook's Zoom setting in Email New Slipstick.com Articles 0
O Setting default format for composing/replying to emails Using Outlook 3
B Outlook Calendar/setting appointments Using Outlook 1
Diane Poremsky Setting Custom Reminder Times New Slipstick.com Articles 0
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
L Setting up my PA's Outlook Using Outlook 7
N "Instant Search" setting a default view Using Outlook 3
H SETTING UP A "NEW" NEVER HAD NEVER USED EMAIL ACCOUNT Using Outlook 9
K Setting Default Email Address for Meeting Replies Using Outlook 3
S Setting up Outlook 2010 to work with custom domain outlook.com account BCM (Business Contact Manager) 3
D Setting defult "Show a room list" Using Outlook 0
Horsepower Setting appointments in calendar Using Outlook 3
J Setting tabs in contacts / notes field Using Outlook 0
T Setting a Default Subject from a certain Signature Using Outlook 0
K Help Needed - setting up Email in Outlook 2013 Using Outlook 3
mikecox setting Default area code in Contacts Using Outlook 5
G Outlook2013 - "From" name doesn't change even when changed in Account Setting Using Outlook 4
D How do I start completely from scratch in setting up Outlook 2013? Using Outlook 6
V View zoom setting changing Using Outlook 1
C Setting up Outlook 10 on Widows 8 using Google Server Using Outlook 3
I Outlook Appointments - Setting default text in message body Using Outlook 3
T Setting Color codes for each user of a shared Calendar Using Outlook 1
J setting date in drafts Using Outlook 4
J Outlook 2010 - email address disappears when setting up new contact Using Outlook 0
V Setting up Outlook 2013 for AOL (POP3) Account Using Outlook 16
V Setting up windows 7 & outlook 2007 w/ Iphone 4 & synch contacts & calendar Using Outlook 9
