Exchange 2003 OWA/OA/AS over NAT and Exchange 2010 CAS
BJ Small
Hello
In trying to do a migration I discovered we are using NAT for 2003 FE Services, these include RPC/HTTP, OWA and ActiveSync. I cannot do a big bang so i need to allow for coexistence during the migration.
with the users accessing these services externally using 14.40.120.240/exchange, how can i configure the CAS to interoperate and what will this mean for redirection? how do i configure this legacy name for 2003? how do configure CAS? do i simply assign the 2010 CAS the link above? how do i get CAS to redirect for users still on 2003?
Usually I would:
1. Add a new DNS for legacy.hosthotels.com and point to exchange FE 2003
2. Change rules to point mail.hosthotels.com to CAS 2010
3. With Host Hotels using ipaddress/exchange as their URL is causing some concern
any suggestions and assistance is helpful.
thanks
Sembee [MVP]
I would expect that most sites are using NAT for OWA.
It doesn't really make much difference - for co-existence you still need two URLs, two IP addresses. This would be a good opportunity to wean off using the IP address, so point the users at the legacy DNS url, rather than an IP address. That would also allow you to use a commercial SSL certificate and avoid errors - very few, if any SSL providers will issue a certificate to an IP address.
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
BJ Small
I'm not trying to be thick but in this case i would create a new URL for the new 2010 CAS and point this URL to the old IP address above, and for the legacy name i would also create a new URL as well which would point to a new IP address.
thanks
Brian Day MCITP
Generally the legacy URL will point to the same IP you have today (the 2007 CAS) and whatever OWA URL you have today is changed to point to the IP of the 2010 CAS servers.Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
M Inbox is not syncing correctly between OWA and Windows 7 Client with Exchange 2003 Using Outlook 4
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
J Exchange 2010 / 2003 OWA Problem Exchange Server Administration 2
C Manage OWA access during the migration from Exchange 2003 to Exchange 2010 (Resource Forest) Exchange Server Administration 4
T How to get Exchange 2003 OWA SSO authentication to work with Internal TMG Array web listener Exchange Server Administration 1
J Exchange 2010 CAS Server OWA Redirection to Exchange 2003 Fail Exchange Server Administration 4
K Exchange 2003 SP2 OWA error 500 / unspecified on Frontend, while OMA and ActiveSync is working, even Using Outlook 3
R OWA ISSUE Exchange 2010 co-existance with Exchange 2003 Exchange Server Administration 3
P Exchange 2003 and OWA url change Using Outlook 3
Z Exchange 2010 OWA and outlook 2003 not able to access from terminal server after redoing the database. Exchange Server Administration 6
A exchange 2010 CAS redirect to Exchange 2003 OWA error Exchange Server Administration 15
B Exchange 2003 EDB corrupt Exchange Server Administration 6
A Exchange 2003 how to stop accepting EHLO and AUTH commands Exchange Server Administration 2
A Rename resource Exchange 2003 Using Outlook 2
R Exchange 2003 to 2013 mail Exchange Server Administration 4
C Exchange 2003 - Outlook 2003 - Calendar entries saving over each other Using Outlook 2
T Exchange 2003, NDR, DNS problems Exchange Server Administration 3
K clear categories on Exchange 2003 & Outlook 2003 Exchange Server Administration 1
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
O Exchange 2003 displaying HTML emails as having attachments Exchange Server Administration 7
S How to leave e-mail on Exchange 2003 server? Exchange Server Administration 1
J Problems starting Information Store Server in Exchange 2003 Exchange Server Administration 13
J I use Windows XP with Microsoft Outlook 2003 and I cannot get int the Microsoft Exchange server. Using Outlook 1
B Move mailbox from Exchange 2003 to 2010 Exchange Server Administration 2
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
K on outlook 2003, how do I set up an out of office reply if I do not use the exchange server Using Outlook 2
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
S exchange 2003 org to exchange 2010 org Exchange Server Administration 2
T Outlook 2003 thinks I'm connected to and exchange server. I'm not. How do I reset Using Outlook 1
H Unable to remove the last exchange 2003 server in the organization Exchange Server Administration 2
H Exchange 2003 to 2010 Transition, Public Folders Exchange Server Administration 2
C Outlook 2003 (or Exchange 2003): Automatically coptying someone on outbound email Using Outlook 2
C Mail folder permissions Exchange 2003/Outlook 2003 Using Outlook 1
M Outlook Mail Format Options - Grayed out 2003 office/outlook in exchange 2007 mail organisation. Using Outlook 3
A I have purchased a replacement computer and installed Outlook 2010. My server is a 2003 small business exchange server. How can I access the calenda Using Outlook 1
M Exchange 2010 Outlook Web App via Exchange 2003 Front End Server Exchange Server Administration 1
J Exchange server 2003 to 2010 Exchange Server Administration 1
L Exchange 2003 to 2010 Migration - Public Folder Replication Failed - Busy/Free Issue Exchange Server Administration 8
D Outlook 2003 is getting an error when trying to open an exchange 2010 mailbox Exchange Server Administration 5
