Exchange 2010 Installation Problem
P
Peter_it
When the Exchange 2010 withered check the system before the installation it gives me the following problem that I can't find its solution so pls if anyone can advise would be wonderful,
Error:
This computer requires the update described in Microsoft Knowledge Base articles 977624 (http://support.microsoft.com/kb/977624). Without this update, the RMS features may stop working.
Click here for help... http://technet.microsoft.com/en-US/library/ms.exch.err.default(EXCHG.141).aspx?v=14.1.218.11&e=ms.exch.err.Ex28883C&l=0&cl=cp
G
Gulab Mallah
One more thing, make sure you are installing as per your OS, like if you have R2 or SP2Gulab | Skype: gulab.mallah
P
Peter_it
Thanks for all on their responce. After fixing this problem I'm facing another one as following which fails the installation, please if any one could advise would be very good, thanks.
Error:
Installing product E:\exchangeserver.msi failed. Fatal error during installation. Error code is 1603. Last error reported by the MSI package is 'Source file not found: E:\Setup\ServerRoles\Common\Microsoft.Exchange.Infoworker.Common.Mailtips.GroupMetricsReaderInterop.dll. Verify that the file exists and that you can access it.'.
AndyD_ [MVP]
Where did you get the installation binaries?
I would copy the Exchange2010-SP1-x64.exe file to a local temp drive and then click on it to unzip and run setup.exe again.
P
Peter_it
This is a demo version I have downloaded from Microsoft website which is ISO file actually.
First I tried to burn it on a DVD and then install from it.
Second I tried to extract the ISO file and then I tried to install from the extracted files
on the both above trials I'm receiving the same message!!!
pls help if you can thanks
F
Frank.Wang
Hi Peter,
Have you downloaded the file as Tim said and installed it?
P exchange server 2010 installation Exchange Server Administration 2
J Question of Exchange 2010 Installation - Organization Name Exchange Server Administration 6
B Installation of Exchange 2010 on a SBS2008SP1 Server. Exchange Server Administration 2
M Exchange Server 2010 Installation error ""The domain is invalid. Property Name: Domain" Exchange Server Administration 4
S Exchange server 2010 installation error Exchange Server Administration 3
S Exchange Server 2010 installation help Exchange Server Administration 2
N Failed Exchange 2010 SP1 Installation PowerShell "unauthorized operation" Exchange Server Administration 2
E Exchange 2010 Installation Exchange Server Administration 4
T Exchange 2010 Mailbox Role Installation Failure Exchange Server Administration 4
B AD Exchange Features Missing After 2010 Server Installation Exchange Server Administration 2
M Exchange 2010 SP1 installation error Exchange Server Administration 5
M New Exchange 2010 Installation Exchange Server Administration 3
N Exchange 2010 Update rollup Installation Order Exchange Server Administration 11
A Order of exchange 2010 roles installation Exchange Server Administration 2
P Microsoft Exchange 2010 installation problems into an Exchange 2007 environment transport service wi Exchange Server Administration 4
M Exchange 2010 and OCS 2007 R2 Installation on the same server? Exchange Server Administration 3
A ACCOUNT FOR EXCHANGE 2010 INSTALLATION Exchange Server Administration 4
S OWA2010 Problem after installation of Exchange 2010 SP1 Rollup1 Using Outlook 4
M Exchange server 2010 installation failed with hub transport server role error Exchange Server Administration 5
J Exchange 2010 installation - A configuration started by another administrator is currently in progress Exchange Server Administration 1
R Exchange 2010 SP1 Mailbox role installation Failed Exchange Server Administration 6
S Exchange 2010 update rollup 4 - installation problem Exchange Server Administration 5
J Error connect smartphone to new Exchange 2010 installation... Exchange Server Administration 9
M 2010 SP1 Installation Fails on Hub Transport: Database is mandatory on UserMailbox after removing prior install of Exchange 2010 Exchange Server Administration 0
E duplicate messages after the installation exchange 2010 Exchange Server Administration 5
R Exchange 2010 SP1 installation error AuthorizationManager check failed. Exchange Server Administration 5
S Exchange 2010 SP1 installation - error message Exchange Server Administration 9
C Free-Busy Unavailable in Exchange 2010 Default installation Exchange Server Administration 16
S Exchange 2010 SP1 Post Installation issues Exchange Server Administration 13
S Exchange 2010 SP1 installation issues Exchange Server Administration 4
I Exchange 2010 installation Exchange Server Administration 3
G Exchange 2010 Installation Question Regarding the Client Access Server External Domain Exchange Server Administration 3
C installation error when installing exchange 2010 cas/hub in exchange 2003 org Exchange Server Administration 10
L How to cleanup active directory after failed Exchange 2010 mailbox role server installation? Exchange Server Administration 5
J EXCHANGE 2010 INSTALLATION Exchange Server Administration 1
E Corrupted Installation of Exchange Server 2010 Won't Repair or Uninstall Exchange Server Administration 2
D Exchange 2010 installation of CAS role fails Exchange Server Administration 2
S Issues during the Installation of the evaluation version of Exchange 2010 Exchange Server Administration 5
M Exchange 2010 Installation Exchange Server Administration 10
Z Exchange 2010 Installation issues related to the IPv6 Exchange Server Administration 10
T Exchange 2010 - Post Installation Issue Exchange Server Administration 3
S Events 9320 and 9359 on new installation of Exchange 2010 RC Exchange Server Administration 24
M Wer.dll Error with Exchange 2010 Beta installation Exchange Server Administration 7
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
