outlook 2003 Free Busy and public folde replica move
P
piloteight
I have a very strange free busy problem. currently transitioning from exchange 2003 to exchange 2010. All exchange 2003 users have been moved to exchange 2010 RU2 . I have users using outlook 2003 are unable to view free busy on some users, when trying to schedule a meeting, the organizer is seeing \\\\ no information available. It so happen these uses with no free busy information happens to be Mac users. outlook 2003 users can view other outlook users free busy, but can't view free busy of Mac users. However, when using outlook 2007, the organizer see the free busy info of these Mac users.. OWA is also fine. outlook 2003 is sp3. I am in the process of moving the Public folder replica/hierachy to exchange 2010 so I can began decommissioning exchange 2003. The public folder instances are not clean after 4 days. Don't know if this is causing the problem or not. Please advise.
raymond
Jonas Andersson [MCITP]
Can you see if the public folders have been replicated to the new server successfully?
Make sure you don't have any smarthost configured on the default smtp virtual server, that can interrupt you from replicate them successfully
Jonas Andersson MCTS: Microsoft Exchange Server 2007/2010 | MCITP: EMA 2007/2010 | MCSE/MCSA Blog: http://www.testlabs.se/blog
Allen Song
Please ensure all the user's replica of the free/busy have moved to the Exchange 2010. You can check the information in Public Folder.
Outlook 2003 uses Public Folder to locate the user's free/busy, so the free/busy have to be updated under SCHEDULE+ FREE BUSY.
For this issue, I suspect the problematic user's free/busy was not moved into the Exchange 2010, even not update. Please find one of the Mac user's client, set the proper time of free/busy interval.
Allen
Allen Song
G
Gulab Mallah
Agree, double check if you have the replica of old server on 2010 and replication is completed successfully.
Outlook 2003 clients will use Public Folders for FB and 2007-2010 will user Autodiscover.
Gulab | Skype: gulab.mallah
P
piloteight
How do I find out if the public folder replica is successful or not. Is there a cmdlet I can run to show this ? I am transitioning from exchange 2003 to exchange 2010.
thanks!
ray
G
Gulab Mallah
EMC--->Toolbox...>Public Folder Management Console...>System Public Folders...>Right click and properties on Schedule + FreeBusy and check the contentGulab | Skype: gulab.mallah
Allen Song
To confirm whether there is something with the replication of the replica, you can check the Application Event Log. Additionally, you can use Gulab's methods to confirm whether you can find the problematic user's entry (free/busy).
Allen
Allen Song
P
piloteight
HI,
I did the following:
>System Public Folders...>Right click and properties on Schedule + FreeBusy, right click on properties of
the following folders.
EX:/o=INFOBLOX/ou=Exchange Administrative Group (FYDIBOHF23SPDLT)
there are 250 total items, and 254KB.
EX:/o=INFOBLOX/ou=First Administrative Group
there are 409 total items, and 312 KB size.
So does this mean I have contents and is working correctly?
thanks!
raymond
Allen Song
We cannot use this method to confirm the Public Folder working Status.
You can use PFDAVAdmin or MFCMAPI tool to view the contents of the SCHEDULE+ FREE BUSY, then please find the problematic user's free/busy in the Items.
Allen
Allen Song
P
piloteight
HI,
I am not familiar with pfdavamin or mfcmapi, could you provide instructions on how to use this tools.
thanks!
raymond
Allen Song
You can first download the PFDAVAdmin, then install it on the Mailbox Server, double click it and click File menu, select Connect, input the Exchange server and GC name, check " Authenticate as currently logged-on user" ption, select Public Folders, click OK button, expand System Folders, expand SCHEDULE+ FREE BUSY, highlight EX:/o=First Organization/ou=Exchange Administrative Group (FYDIBOHF23SPDLT), click Items Tab in the right panel. You will see the entries of the each user.
Allen
Allen Song
B Outlook 2003: Meeting Organizer will be set as always free or busy status Using Outlook 1
T Outlook 2003 free busy vfb file creation problem Using Outlook 12
W Outlook 2010 Free/Busy Data not updated\viewable - Exchange 2003 SP2 Using Outlook 2
B Outlook 2003 Free/Busy issues after migrating to Exchange 2010 Exchange Server Administration 5
J Outlook 2003 - free/busy cal after 1/1/2008 Using Outlook 13
I Outlook 2003 shows html code when To: field is empty Using Outlook 5
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
