Anyone had problems using OLF.Items.Count with Outlook 2010?
Gemma
My dad has written a program for me to capture data from emails and add them to an excel workbook. It is supposed to search my inbox for emails with a specific subject title and once the correct ones have been scanned and the data captured, transfer them to the 'Scanned' folder.
He has tried and tested the program on his outlook 2007 and it works fine except that when the emails are transfered to the 'Scanned' folder, a copy is left in his 'Inbox' which he has to then purge. This is not a problem as it's for my pc, not his.
When it comes to using the program on my outlook 2010, no copy is left in the 'Inbox' however we are getting an error message which relates to a problem with the code line With OLF.Items(i).
Just wondering whether this could be the result of a difference between the 2007 and 2010 versions of Outlook and if anyone knew anything about it?
Many Thanks,
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
O Importing Mbox - anyone out there having experience with this tool... Using Outlook 3
J Can Anyone Help?? Outlook VBA and Custom Forms 1
V Anyone Using CodeTwo Sync for iCloud ? Using Outlook 28
S Anyone know how to transfer Outlook Express "Identities" to Outlook 2010 ... Using Outlook 1
M Anyone with this Microsoft Outlook issue can help? Using Outlook 1
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
D Does anyone understand Outlook 2010??? Using Outlook 1
J Does anyone know if there is a theoretical limit to the number of personal folders permitted within Using Outlook 2
S My Outlook Filing Cabinet has disappeared! Does anyone know how I get it back?? Using Outlook 1
A Need to upload Pic in Microsoft Outlook... Can anyone suggest How? Using Outlook 1
K Does anyone know how to turn off auto capitalization in Outlook 2007 running on Windows 7? Using Outlook 6
R Anyone have a sample macro for Outlook 2007 (setting the zoom)? Outlook VBA and Custom Forms 1
