Another OWA Timeout thread - possible Forms/Basic Authentication with IIS issue
H
hoodoo2
Issue: customer reports that any action that opens a new window in OWA (i.e. New Message / Open Attachment) fails and displays authentication prompt.
This looks to be happening after ~30 minutes (the customer in question uses OWA for staff in certain offices all day, rather than Outlook).There does not seem to be any distinction between selecting Public or Private, in terms of this timeout occuring at around ~30 minutes.
I'm working on the assumption that it's to do with the Forms Auth cookie default timeout of 30 minutes. I've created/adjusted the appropriate regkeys from http://technet.microsoft.com/en-us/library/bb124819.aspx to boost Public to a 1 hour timeout for testing, and Private to 8 hour timeout, then restarted the MS Exchange Forms Auth service and reset IIS.
This behaviour continues to occur.
Next I confirmed that OWA is set to use Forms Auth in the EMC.
Next I checked IIS Virtual Directory auth settings and discover it is set to Basic Authentication, not Forms Authentication. I presume that this means that the cookie isn't generated / is ignored.
However, if I select Forms Authentication, reset IIS and restart the MS Exchange Forms Auth service (as done for changing the cookie timeouts), once a user logs in to OWA they are greeted with a 404 error.
I also tried altering the powershell line from http://social.technet.microsoft.com...0/thread/27887926-c47e-4a82-90e7-b9f7afc49d5b to enable Forms Auth and Disable Basic Auth for the OWA Virtual Directory.I assume this functions in the same way as applying it via the IIS GUI - with the same result. (This has since been reset to default values, as has the IIS Auth so that users can continue to login.)
My knowledge of IIS is hazy at best, so I'm not sure what my next step should be - I've had a look at a variety of forum posts, but none seem to cover this specific scenario (with the Virtual Directory using Basic Auth / having issues changing to Forms Auth).
G
Gen Lin
Please try to create a new OWA virtual directory and see if the issue persists:
1. Open EMS, type:
Remove-OwaVirtualDirectory -identity " owa (default web site)"
2. Then create a new OWA:
New-OwaVirtualDirectory
R Time for another article on contact cards? Using Outlook 0
M Moving mail to another folder is much slower than before (Office365) Using Outlook 0
B Moving account, contacts & emails to another H/D with MSOutlook Using Outlook 5
M Shortcut to another outlook item Using Outlook 0
M FW Email via Outlook and another requirement Outlook VBA and Custom Forms 1
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
Diane Poremsky Copy New Appointments to Another Calendar using VBA New Slipstick.com Articles 0
D Unable to Send On Behalf of Another User Exchange Server Administration 0
D EXPORTING MS EXCHANGE EMAILS to another platform Exchange Server Administration 10
mrmmickle1 UserProperties VBA to move message to another folder Outlook VBA and Custom Forms 7
P Office 365 manage another person's calendar Using Outlook 0
TheDavidSlight Daylight savings - another subtle bug ... Using Outlook 3
C Custom Application Form send Email to Another User Using Outlook 1
A Calling one module from another Outlook VBA and Custom Forms 2
M How to duplicate content of one field in another field? Outlook VBA and Custom Forms 3
iwshim Transfering mail from the outbox to another computer Using Outlook 0
I Outlook 2010 Replicating mixed PST/OST profile to another desktop Using Outlook.com accounts in Outlook 1
J Macro for replying to One Email with another Using Outlook 1
wallisellener Another BCM Authentication thread BCM (Business Contact Manager) 5
mikecox Forward email to another address; not with Rules Using Outlook 3
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
I How to block time in another calendar without invite? Using Outlook 2
Paul Butticaz Copying Contacts from SharePoint List (connected to Outlook) to another Conacts folder Using Outlook 1
P Item cannot be saved because it was modified by another user or window Using Outlook 8
Klaas "To Address" duplicated when moving msg to another folder Using Outlook 2
Britonius Delegate cannot view meetings marked Private by Another Chairperson Using Outlook 7
P Macros in Word 2003 - how to transfer to another Word 2003? Using Outlook 1
F Adding User Defined Field to another form Using Outlook 0
D Cancelled Meeting Notifications to another mail address Outlook VBA and Custom Forms 1
M Print Attachments from another mailbox (not default) Outlook VBA and Custom Forms 2
