Outlook 2010 cached mode registry entry
mvirata
I am looking for the registry entry to enable/disable cache mode for Outlook 2010. I know how to do it in Outlook 2003/2007.
For Outlook 2003/2007 the location is here:
[HKCU\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\<ProfileName>\13dbb0c8aa05101a9bb000aa002fc45a]
Outlook 2003:
00036601 (REG_BINARY)
enabled value; 84 01 00 00
enabled with Public Folders/Favorites: 84 05 00 00
disabled value; 04 00 00 00
Outlook 2007:
enabled value; 84 19 00 00
disabled value; 04 10 00 00
In Outlook 2010 you can browse to the same place in the registry but there is only one entry in there. I tried enabling cache mode from Outlook and then exporting the key. I then disabled cache mode and tried merging the key and it did not work. There must be somewhere else in the registry that Outlook 2010 is writing to.
Also I am familiar with how this can be done via group policy but I need this in a script which I will be deploying via Zenworks so the registry key is the optimal place for me to do this.
Thanks in advance
E
Ed Crowley [MVP]
You might be able to find it by looking to see how the GPO does it.Ed Crowley MVP " There are seldom good technological solutions to behavioral problems."
mvirata
I found the solution using a Registry Tracer. I should have searched the key. (doh!). In the registry it is located in d4c3fff326ad1c498c9982bc456d4c6a in Outlook 2010.
Outlook 2010
Cached Exchange Mode is controlled by the following key;
[HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows Messaging Subsystem\Profiles\Outlook\d4c3fff326ad1c498c9982bc456d4c6a]
R Microsoft Outlook 2010 - Non Cached Mode Using Outlook 0
R Mailto link inside Outlook 2010 being cached? Using Outlook 1
P Reply All does not work in Outlook 2010 Cached mode Using Outlook 4
P Outlook 2010 search of PST files doesn't work unless in cached mode Using Outlook 3
S Exchange 2010 outlook 2010 outlook anywhere cached mode Exchange Server Administration 2
M Outlook 2007 (cached mode), Exchange 2010 - Cant download Offline Address Book Exchange Server Administration 6
R Outlook 2010 cached mode cannot see GAL but Outlook 2007 can via Exchange 2010 Using Outlook 2
H Outlook 2010 l No sync at home Office with DSL Internet Connection (cached Mode) Using Outlook 2
S Outlook 2010 - Cached/Offline Mode and Local File Sever Using Outlook 2
Z Exchange 2010 / Outlook 2010 cached mode Exchange Server Administration 4
L Outlook 2010 Cached mode - Refresh HTML Email Image Using Outlook 1
J Outlook in cached mode with exchange 2010 doesn't update Using Outlook 4
H Outlook 2010: Conversation Clean Up and Ignore only functional in Cached Exchange mode? Using Outlook 1
R Is Outlook 2010 Cached Mode a security risk? Using Outlook 5
T OAB cannot be downloaded with error 0x8004010f (Outlook 2007 cached mode + Exchange 2010) Using Outlook 6
M PST import from Outlook 2007 to 2010 - Address Book contacts all in 1 group Using Outlook 3
