Right click to delete will crash Outlook
C
cbskean
Everytime I right-click to delete items, it crashes Outlook program.
Somasundaram Pandiaraj
Start Outlook in safe and check if you"re able to click on "Deleted items". The steps below will help you open Outlook in safe.
1. Click Start > All Programs > Accessories > Run
2. Copy and paste the content below and press Enter:
Outlook /safe
If you"re able to work with Outlook, then follow the steps below to disable add-ins.
1. Click File menu, click Options > Add-in, click Go button in the Manage: Com-in Add
2. Check if there is any add-in; clear the checkbox to disable it
