Odd OWA Issue; Messages Sending as HTML Code
P
Paul Newell
Hi all,
A few of my users (not all of them, with no discernable pattern other than being on a 2003 back-end server) are reporting that when they compose a new message in OWA (my older 2003 FE server; 2010 CAS seems uneffected) that the recipient receives a message that is only HTML code. It only seems to be recipients external to my domain, however.
The way they show up is odd too; it's HTML, but there's a "Space" between each letter. Here's a sample of what they look like (hopefully it will show up):
< h t m l > < h e a d > < m e t a h t t p - e q u i v = " C o n t e n t - T y p e " c o n t e n t = " t e x t / h t m l ; c h a r s e t = u t f - 1 6 " > < / h e a d > < b o d y > & # 1 8 4 9 2 ; TML dir=ltr>& # 1 8 4 9 2 ; EAD>& # 1 5 3 7 0 ; META content="text/html; charset=unicode" http-equiv=Content-Type>& # 1 5 3 7 0 ; META name=GENERATOR content="MSHTML 8.00.7600.16671"& # 1 5 4 2 2 ; /HEAD>& # 1 5 3 7 0 ; BODY> & # 1 7 4 6 8 ; IV& # 1 5 4 2 2 ; FONT color=#000000 size=2 face=Arial>Kyle's E-mail Test& # 1 5 3 9 2 ; /FONT>& # 1 2 0 9 2 ; DIV>& # 1 2 0 9 2 ; BODY& # 1 5 4 2 2 ; /HTML> < i > P u r s u a n t t o T r e a s u r y R e g u l a t i o n s c o n c e r n i n g C i r c u l a r 2 3 0 , p l e a s e b e a d v i s e d t h a t a n y t a x a d v i c e c o n t a i n e d i n t h i s c o m m u n i c a t i o n w a s n o t i n t e n d e d o r w r i t t e n t o b e u s e d , a n d c a n n o t b e u s e d , b y t h e r e c i p i e n t f o r t h e p u r p o s e o f a v o i d i n g p e n a l t i e s t h a t m a y b e i m p o s e d u n d e r t h e I n t e r n a l R e v e n u e C o d e . < / i > < / b o d y > < / h t m l >
Any thoughts here? As you can see, it displays all of the HTML formatting. The "Body" of the message is the spot that says "Kyle's E-mail Test" and at the very end is a Circular 230 discloser (as the core of our business is financial services).
I'm going to try and reboot both the 2003 Back-End and Front-End servers later, as it only seems to effect users with 2003 mailboxes, but I'm not even sure that would take care of the issue.
Thanks in advance!
P
Paul Newell
I think I have it figured out - the issue was due to potentially feuding disclaimers.
I thought that the Hub would only apply disclaimer Transport Rules for messages coming from mailboxes on a 2010 database. Is that not the case? Will messages being sent from 2003 users be appended the same way? It makes sense that they would...
We have a program (Exclaimer Mail Utilities) to append that disclaimer to messages on our 2003 Back-end server. In preparation for switching everything over, I created the new disclaimer on the 2010 server a couple weeks ago, but didn't set it as my primary SMTP server until this week, which must have been when the issues started.
So other than verification of what all will have the Transport Rule applied, I'd also like to know if anyone has a list of HTML tags that will work with Exchange 2010. The disclaimer I wrote started with a simple "" and ended with "" (replacing the square-brackets with angle-brackets, of course), but I'm wondering if that wasn't enough to properly format it, or if it needs the "Microsoft Version" of HTML.
In any event, my 2003 users are all able to create/send messages in OWA properly now.
Thanks again!
E
Evan Liu
Hi Paul,
Exchange 2010 disclaimer text can include HTML tags. This allows you to create messages with the rich styling functionality available in HTML. Additionally, HTML tags can include inline Cascading Style Sheets (CSS). Messages sent in the HTML format can display the rich disclaimer messages.(Note: You can also configure a transport rule with text-only disclaimers by not using any HTML tags.)
You can find an example (of disclaimer text used to create a HTML disclaimer with an IMG tag and embedded CSS) from this link:
Understanding Disclaimers
http://technet.microsoft.com/en-us/library/bb124352.aspx#HTMLTags
You can know more about the HTML tags that will work with Exchange 2010 from this link:
Using Disclaimer in Exchange Server 2010(Please Note: Since the web site is not hosted by Microsoft, the link may change without notice. Microsoft does not guarantee the accuracy of this information.)
http://www.msexchange.org/articles_tutorials/exchange-server-2010/migration-deployment/using-disclaimer-exchange-server-2010.html
Here is a related article for you:
Configure a Disclaimer
http://technet.microsoft.com/en-us/library/dd876914.aspx
If anything is unclear, please feel free to let me know and I will be glad to help.
Best Regards,
Evan
P
Paul Newell
Hi Evan,
Thanks for the reply.
I already found the two Technet articles you posted, but I noticed the tag "div style="font-size:9pt; font-family: 'Calibri',sans-serif;" and I was a little concerned that it might be looking for the MSO HTML that we needed to conform to when creating HTML front-ends in older versions of Office.
The msexchange.org article looks nice too; thank you.
In any event, I tested the disclaimer on my account (2010 mailbox) and a colleague's account (2003 mailbox), and it seems to work fine, so I guess the issue was some conflict between the two disclaimers being applied.
V Calendar event acting odd Using Outlook 7
C Odd error message not found in Google search Using Outlook 1
R Outlook 2013 - Odd Sync behaviour Using Outlook 1
V Odd data file? Using Outlook 5
D This is odd Using Outlook 2
O How do I get rid of odd formatting of new e-mails? Using Outlook 3
U Odd behaviour for auto-receive Using Outlook 2
C Open message is stuck minimized -Odd behavior when replying to a message(2010) Using Outlook 1
V Odd Situation with Outlook 2010 Using Outlook 1
S Odd message delays... Exchange Server Administration 6
B Outlook 2007 at odd times shuts down then states it is looking for problem then starts up again Using Outlook 1
J Exchange 2010 behind TMG 2010 - odd per-user problem Exchange Server Administration 4
D Test-SystemHealth yeilds odd warning Exchange Server Administration 3
R Odd Directory Services Event Errors Exchange Server Administration 6
P Odd IMAP Issue; New Mail Automatically Marked for Deletion Using Outlook 5
3 Odd issues with deleting messges Using Outlook 3
P Unable to print Calendar when choosing to print 'odd' or 'even' pages. Using Outlook 1
B Odd .pstst files Using Outlook 19
H Odd symbol when stripping characters using vba Outlook VBA and Custom Forms 3
J OWA vs. Outlook 2016 Bandwidth Exchange Server Administration 1
Diane Poremsky New Office365 Feature: URL Preview in OWA New Slipstick.com Articles 0
S Cannot disable OWA light Exchange Server Administration 5
J Stuck using OWA Exchange Server Administration 0
T Outlook Calendar Sync MY GOAL: see work calendar on home desktop w/o OWA Using Outlook 2
T Sync OWA? Exchange Server Administration 0
O Multiple simulteniously opened OWA 2010 accounts in one browser work fine ! Using Outlook 3
S Newly added user doesn't show up in GAL but available in OWA, Using Outlook 0
B OWA Calendar Views not available Exchange Server Administration 2
B Searching OWA Additional Mailbox - in which Secondary folder is the email? Using Outlook 1
D OWA and Windows 8 Exchange Server Administration 1
Z OWA Mailbox unavailable Exchange Server Administration 2
R Lost Outlook 2007 message found in OWA Using Outlook 4
D OWA Send invitation AS (not from) Exchange Server Administration 1
E OWA phones home too much? Exchange Server Administration 1
S Cannot open any attachment from OWA Exchange Server Administration 2
T Syncing OWA 2010 to Outlook 2007 Exchange Server Administration 15
R OWA can't delete mail Exchange Server Administration 8
J Outlook and owa access Using Outlook 1
S Track emails in OWA Exchange Server Administration 1
T OWA and post dating Exchange Server Administration 1
S Unable to Sync Phones but OWA connects Exchange Server Administration 1
