500 error after authenticating in OWA - Exchange 2010
Brian_Jones
My exchange server installed ok, and OWA was working fine, and then the other day OWA just stopped working. Whenever I authenticate, it just gives a 500 error.
I've tried looking at the logs but can't see anything, and I've checked the forms service and that is started ok.
I've turned off friendly errors in IE but i'm not getting anything more than a basic 500 error.
Help!
MCP, MCDST, MCTS x 6, MCITP x 3
Please don't forget to mark this post as an answer if it is the solution to your problem!
If you like trance music, please subscribe to my podcast Trancendance Podcast
View my MCP Certifications
Follow me on Twitter
Brian_Jones
Right, something at some point had added <add value="index.php" /> into my web.config file and this was why it wasn't working. After removing it, my php sites are still working and now OWA is too.
L I am getting a 500 error message that I have exceded my limit on sending emails. Using Outlook 2
K Exchange 2003 SP2 OWA error 500 / unspecified on Frontend, while OMA and ActiveSync is working, even Using Outlook 3
F Re: The WinRM client received an HTTP server error status (500) Exchange Server Administration 1
J Change Subject of 500 mails sitting in Outbox with Macro Using Outlook 6
C Outllook Migration - Office 200? - 2010 - Shared Mailbox Export-Bulk 500 users Using Outlook 1
K Calendar item and invitation not opening in OWA (HTTP 500) Using Outlook 6
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error New Slipstick.com Articles 0
Diane Poremsky RMS Error: System clock has been tampered with New Slipstick.com Articles 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet New Slipstick.com Articles 0
K Error: Paper Size Invalid Using Outlook 0
