Will 'ldap modify' command work on some Active Directory fields?
P
p66272
Do I need to enable some things in order for LDAP Modify command to work in Active Directory?
Can someone point me to any doc that will tell me what fields in AD I can modify and what I cannot?
K
Khoj Sahiwala
I think you can modify almost everything that is permitted by system. Few things you will nbot be able to change even if you have highest permsisions.
use a utility like adsieidt , admodify to check and change the thinsg you want , then directly using LDAP modify command.
For standard Bulk operatiosn Admodify is a good utility
http://admodify.codeplex.com/
