Re: Error 5009 when using scheduling assistant for a meeting
DavidCE
I have the same issue. It occurs, when a contact has an internet free-busy url but the data could not be retrieved. Unfortunately in my case, the url does exist and contains an .ics file generated by Exchange. I have tried using the Publish to WebDAV-feature but no luck. The .ics files look the same.
DavidCE
I have now tried scheduling a meeting using Outlook 2010, but the fb info could not be retrieved. Only a hint pops up saying " An error occured reading internet free busy data" . The url is accessable via IE, i can download and open the ics file allright using Outlook (it integrates as a calendar).
Just for testing I subscribed to the calendar's url via Google calendar and within seconds everything was downloaded.
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error New Slipstick.com Articles 0
Diane Poremsky RMS Error: System clock has been tampered with New Slipstick.com Articles 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet New Slipstick.com Articles 0
K Error: Paper Size Invalid Using Outlook 0
M Error 0x 800CCC92 Using Outlook 0
Diane Poremsky Cannot start Microsoft Office Outlook Error Message New Slipstick.com Articles 0
S Autosave attachments error using Len Outlook VBA and Custom Forms 2
J Error 75 Outlook VBA and Custom Forms 4
B "The properties of the message…have been changed" error Outlook VBA and Custom Forms 1
I Windows 10 - .msg files on disk show Explorer popup error Using Outlook 5
