outlook unable to view public folders and autodiscovery not working
I
irweazel
I have had a 2010 setup running fine for at least a month now. i was ready to start moving people over from 2007 when i ran into this error.
in existing 2010 mailboxes using 2010 outlook i can't view public folders any more - it tells me the server is unavailable.
When i try and setup on a new PC with out 2007/2010 autodiscover finds the 2010 MB server but tell's me its offline - when i change to the CAS server it opens the mailbox fine.
Autodiscover seems to be working, i am not seeing any errors in the eventlog or on ExchBPA - at a complete loss....
Public folders work fine from OWA (2010)
cheers
Chris
Sembee [MVP]
With Exchange 2010, users not longer connect to the mailbox server, they connect to the CAS server. All connections are made to the CAS server. Are you trying to override what autodiscover is returning?
Do you have a public folder store on Exchange 2010? Have you replicated the public folder content to that store? It doesn't happen automatically. If you don't and you wish to migrate off Exchange 2007, then you will need to create one and replicate the data.
If you do, ensure that the correct public folder store is set on the properties of the mailbox database.
I would also suggest that you create a CAS array now before you move any more users on to the Exchange 2010 platform. It can make life easier later on. http://blog.sembee.co.uk/post/RPC-Client-Access-Array.aspx
Simon.
Simon Butler, Exchange MVP
Blog | Exchange Resources
avant-guvnor Unable to view certain emails in Outlook 2016 Using Outlook 16
D Unable to view Outlook Meeting Invitations Using Outlook 7
I Outlook 2010 - Unable to view embedded / in-line data pasted from Excel 2010 into Lotus Notes e-mail Using Outlook 5
A Outlook 2007 unable to view new/unread emails in Inbox, but OWA 2007 have not issue displaying/listi Using Outlook 6
J Outlook 2003 with Outlook Connector - added new account, unable to view any items in inbox, nor send from that account. Help please! Using Outlook 7
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
A Outlook 2016- unable to have all subfolders expanded when opening outlook Using Outlook 11
Tim King Outlook 365 unable to change accounts Using Outlook 0
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
C Unable to see meeting attendees Outlook 2010 Using Outlook 5
UncleBill Unable to delete items from gmail IMAP Trash using Outlook 2010 Outlook VBA and Custom Forms 5
K Unable to activate QueryBuilder in Outlook 2010 (32bit) with Windows 7 (64bit) Using Outlook 1
S unable to send email from my second address (outlook 2007) Using Outlook 2
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
H Outlook 2010 unable to send iCloud account e-mail after iOS 7 upgrade Using Outlook 12
A Unable to send with attachments in Outlook 2013 (Exchange ActiveSync) Using Outlook 2
F Outlook 2010 unable to delete emails from scanner Using Outlook 1
T Unable to open msg files in Outlook 2010 Using Outlook 11
P Unable to delete custom forms in outlook 2010 Using Outlook 1
D Unable to transfer rules from one Outlook computer to another Using Outlook 5
T Unable to attach message as an attachment in outlook Using Outlook 5
J outlook having sort by date or from unable to display sender name. Using Outlook 2
D Unable to move the tasks pane in the To-do bar in Outlook 2007 Using Outlook 1
M Unable to send email to gmail - using Outlook 2007 Using Outlook 3
H Unable to receive emails in Outlook 2010 from webmail address Using Outlook 5
M 0x800CCC15: Outlook 2003 Unable to Connect to ISP after 12/14/2010 Updates Using Outlook 2
X Exchange 2007 Outlook Anywhere Clients unable to retrieve GAL Using Outlook 9
V Outlook - Unable to Create New Email Account Automatically Using Outlook 2
C I am unable to open web links in my Outlook mail. I get an error message that states: This function Using Outlook 1
P Outlook Crashed. Unable to Access E-Mail Older Than Monday Using Outlook 2
G OUTLOOK 2007 UNABLE TO RECEIVE EMAILS CAN'T RUN INBOX REPAIR TOOL AND ERROR (OX8E0CCC18) Using Outlook 2
W Unable to sync Outlook contacts and calendar since upgrading from Outlook 2007 to Outlook 2010 Using Outlook 1
M Unable to receive or send e-mails in Microsoft outlook Using Outlook 2
R Outlook 2003: Insert, Item: Unable to insert an old email into a new email Using Outlook 2
O My contacts are on Hotmail not Outlook so unable to sync! Using Outlook 2
D Unable to search contacts in Outlook 2003 - Exchange 2010 Using Outlook 2
R Unable to open/preview attachments in Outlook 2010 Using Outlook 4
B Unable to use Addressbook form Contacts file in Outlook while Outlook Express does allow this. Using Outlook 1
O Unable to sent email, 'Microsoft outlook cannot sign or encryt this message, no certification which can be use with this address...' Using Outlook 2
D Outlook 2010 unable to use mail when in home wireless network. Using Outlook 3
B Outlook 2003 unable to see sub-contacts Using Outlook 1
