Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2?
Johan Schurmans
If we open a new meeting request with an Outlook 2010 client in combination with an Exchange 2007 SP2 mailbox, the suggested times window gives following message: " Suggestions cannot be provided because free/busy data could not be retrieved." Free/busy is working though.
Opening the same mailbox with Outlook 2007, the " suggested times" feature works fine!
Does anyone knows how to troubleshoot this? The combination Outlook 2010 feature/Exchange 2007 should be supported: http://technet.microsoft.com/en-us/library/cc178996.aspx
Johan
C
Cabronsote
Good morning,
I am seeing a similar issue occur but the client doesn't seem to matter. I see " no information no free/busy information could be retrieved" for some mailboxes when I view a meeting request through the scheduling assistant using Outlook 2007 or Outlook 2010.
I can open another users calendar and view it's contents.. just can't get the free/busy via the scheduling assistant.
Thank you for your help,
IBD
F
Frank.Wang
Hi Johan,
Do all users have the issue?
Does outlook run in internal or Outlook Anywhere?
Are you running in Exchange Hosted?
B Sorting suggested times in room finder Using Outlook 1
M Outlook 2010 cannot find suggested times with Exchange 2007. Using Outlook 5
V Suggested Contacts are gone Using Outlook 10
L Suggested contacts are not retained after exiting Outlook 2010; Windows 8.1 Using Outlook 4
I Outlook 2010 - Remove or Hide Suggested Contact Folders Using Outlook 1
Commodore Suggested Contacts by last added Using Outlook 1
D Remove or Disable Suggested Contacts Using Outlook 3
D How to make Contact Groups appear in Suggested Contacts Using Outlook 1
W How do I permanently disable "Suggested Contacts" as well as delete their apparently undeletable "fo Using Outlook 7
C Suggested Contacts not working in Outlook 2010 Using Outlook 2
T Suggested Contacts lost when trying to merge into contacts Using Outlook 1
J Diane's Delay Delivery at Specific Times Questions Outlook VBA and Custom Forms 5
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
T Outlook 2016 Unresponsive 30/40+ Times A day Using Outlook 3
I Dialog called up multiple times when saving emails from macro Outlook VBA and Custom Forms 2
Diane Poremsky Delay Delivery of Messages Sent at Specific Times New Slipstick.com Articles 0
P Appointment times are off by one minute Using Outlook 1
Diane Poremsky Setting Custom Reminder Times New Slipstick.com Articles 0
S Mails getting downloaded multiple times Using Outlook 1
T outlook cal for mac changes times of recurring meetings on its own Using Outlook 1
J Change reminder times of future appointments Using Outlook 1
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
R 2013 64-bit Due times (deadlines) on tasks: how to set Using Outlook 1
X When travel between time zones Calendar Daily Items a fixed times vs Meetings? Using Outlook 2
O Outlook Calendar 2007 - Invitation Times Using Outlook 19
Commodore Recurrence for N times, and one gets cancelled Using Outlook 3
K Can Outlook be launched with the /cleanreminders switch multiple times? Using Outlook 2
E Outlook rule only active certain times of day Using Outlook 6
G appointment times are wrong Using Outlook 3
N How can i hsve appointments and events to not display start or finish times Using Outlook 2
A Problem syncing any changes to appointment times on PDAs ... Using Outlook 11
M Outlook 2010 is loading many times already received emails from external acc. Using Outlook 4
D Outlook 2007 Reminder Times Change When User Changes Time Zone in Date/Time Using Outlook 4
B Recurring meeting times off by several hours Exchange Server Administration 5
J Can't print appointment times on Monthly View Calendar? Using Outlook 4
J Can't print appointment times on Monthly View Calendar? Using Outlook 0
C Outlook 10 not showing Proposed New Times Using Outlook 1
J Recurring event (from 2006 and deleted multiple times) continues to send me multiple reminders Using Outlook 1
P All of a sudden I cannot open the INBOX file. It asks me to close any application and restart. Done that several times. Nothing Using Outlook 1
V Daylight savings times X Exchange 2007 pop3 Using Outlook 2
S Outlook times out checking POP3 accounts Using Outlook 8
O Outlook 2010 crash 5 times / per day Using Outlook 3
à owa and powershell take times on exchange 2010 Exchange Server Administration 8
J We want to hide all calendar appointment details and only show free/busy times. Using Outlook 9
A Outlook 2007 periodically (1-2 times per day)locks up when trying to send email. I digitally sign all mail. When Outlook became non-responsive Using Outlook 2
C Change default reading font in Outlook from Times New Roman 12 point to Arial Using Outlook 2
B All times listed are in the following time zone: Customized Time Zone Exchange Server Administration 1
O email sent multiple times to the recipients Using Outlook 1
