Custom permissions using SQL 2008 Enterprise with Business Cotact Manager for Outlook 2010
F
fun-e-mahn
My BCM database resides on SQL Server 2008 Enterprise Edition and I would like to customize user permissions for BCM based on Database permissions. Specifically, I would like to assign an AD group users Read-Only access to the database and/or specific tables. I realize this may not in fact be supported by Microsoft, but is it theoretically possible?
Any input on this would be very much appreciated.
Kind regards,
Steve
L
Larry
Hi Steve
You can make a database read-only usng the Stored Procedure 'sp_dboption' For more info take a look at the following link (there is a 'read only' option)
http://msdn.microsoft.com/en-us/library/aa933268(SQL.80).aspx
However, while SQL Does support a Read-Only option, BCM was not tested with read-only databases - you might experience problems with BCM after setting a database read-only
Hope this helps!
Larry
E Custom formula for columns Using Outlook 3
witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
O Searching for Custom Flags Using Outlook 3
P Outlook custom fields "events" Using Outlook 0
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
