Exchange Autodiscover SSL issue
archibaldicus
Situation:
- Internal AD domain corp.domain.com with Exchange 2010 installed.
- OWA access: URL webmail.domain.com works fine with a valid SSL certificate for *.domain.com
- When outlook clients connect internally, they are presented with a certificate warning, saying that the host does not match the certificate. This is because the client access server presents itself as server.corp.domain.com, which doesn"t match the *.domain.com certificate.
Question:
How do we solve the ssl error for outlook clients on the LAN, taking into account that:
- We want to use the Autodiscover service;
- We do not want to change the OWA URL;
- We do not want to change the SSL certificate.
Do we setup a separate internal Autodiscover website with another valid certificate for *.corp.domain.com for the internal Outlook clients? If yes, can we create our own internal CA for the certificate?
Regards,
Stijn
Steve Goodman
Hiya,
Is there any reason why you don't want to change the cert to a subject alternative name certificate? This is the easiest fix to your problems and wildcard certificates aren't recommended.
Are there any issues stopping you creating a DNS entry like " server.domain.com" and then changing the InternalURL for EWS, OAB, which is what's probably tripping up your Outlook clients.
Steve
Steve Goodman
archibaldicus
Thanks for your reply. The DNS entry for server.domain.com already exists and works, but when you configure an outlook client, it automatically turns it into server.corp.domain.com and generates the SSL security warning. I must add that we actually have 2 AD's setup. One for domain.com as root domain, and the one we setup exchange in, i.e. corp.domain.com.
Regards,
Stijn
Steve Goodman
Hiya,
If you use the following commands:
get-oabvirtualdirectory
and
get-webservicesdirectory
Do you see the server.corp.domain.com listed for each?
Steve
Steve Goodman
archibaldicus
Both commands give the server.corp.domain.com as output.
On the certificate reply, I assume we should generate a certificate using the EMC and fill out all URLs (server.corp.domain.com for internal, webmail.domain.com, etc) and send that to Verisign or Godaddy or whatever?
Regards,
Stijn
Steve Goodman
Hiya,
OK, that output is what I expected. Those two URLs are used by Outlook to set Out of Office and download the Offline Address Book amongst other things. If you're getting the cert errors during usage of Outlook (and mail delivery into and out of Outlook works), then these are the likely culprit.
You could change the InternalURL to server.domain.com use the Set-OABVirtualDirectory and Set-WebServicesDirectory commands - however as it's your production environment and I'm not sure about your exact setup, you need to have understand what this is doing and if possible test it out first. If you make the changes server-side, you will need to get an Outlook client to update it's settings; it should do this automatically, but you can force this by choosing the " Repair" option in the Email Accounts settings panel in Outlook.
Regarding a SAN/UCC certificate, you are quite right about generating it using the EMC. You may want to have a think about if any other hostnames may be needed - the generation wizard will give you some pointers. Obvious ones are if you use another address/server name for Outlook Anywhere and of course autodiscover.corp.domain.com, autodiscover.domain.com.
Steve
Steve Goodman
archibaldicus
I pointed the OABVirtualDirectory and WebServicesDirectory to server.domain.com. The SSL errors seemed to have dissappeared until all of a sudden, I got it again. They appear a lot less frequently now, so I was wondering if Outlook is using an SSL connection for something else as well?
We will also try to get a proper SAN certificate that will cover all *.corp.domain.com and *.domain.com hostnames.
Regards,
Stijn
Steve Goodman
Hiya,
That sounds like when auto discovery is periodically running on the Outlook Client
You may want to also update the SCP record (that's the record in Active Directory that tells domain joined clients where to find AutoDiscover) to amtch that sever.domain.com value, or (preferably) if you have it configured in your internal DNS, autodiscover.domain.com - e.g.
Get-ClientAccessServer | Set-ClientAccessServer -AutoDiscoverServiceInternalUri https://server.domain.com/Autodiscover/Autodiscover.xml
or
Get-ClientAccessServer | Set-ClientAccessServer -AutoDiscoverServiceInternalUri https://autodiscover.domain.com/Autodiscover/Autodiscover.xml
Hope this helps and have a good holiday season!
Steve
Steve Goodman
EXChange2013 Exchange 2013 AutoDiscover Tweaks? Exchange Server Administration 0
K testing autodiscover and exchange coexistence Exchange Server Administration 2
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
Z Autodiscover Points to defunct Exchange 2010 Server Exchange Server Administration 5
L Reinstall IIS / Autodiscover virtual directories on an computer running Exchange 2010 server? Exchange Server Administration 6
I outlook 2016 manual exchange config Using Outlook 0
Fozzie Bear Office 365 Home Premium with Exchange Online email accounts Using Outlook 3
S What is /O=FIRST ORGANIZATION/OU=EXCHANGE ADMINISTRATIVE GROUP(***************)/CN=RECIPIENTS/CN=... Using Outlook 5
Commodore Microsoft Exchange Add-in Using Outlook 2
D Winmail.dat with MS Exchange Personal and Outlook.com Using Outlook.com accounts in Outlook 5
I Outlook 2013 Transition to Exchange - weirdnesses Using Outlook.com accounts in Outlook 4
E you don't have permission to perform this action exchange 2016 Exchange Server Administration 0
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
