Outlook 2010 - Your network adapter does not have a default gateway.
C
CorryMFG
When setting up Office 2010 / Outlook on an XP box with no gateway, I receive message that Outlook cannot log on. No gateway defined. I have an internal Exchange 2003 server. I tried the solution in KB913843 but I do not have a RPC entry in my registry. I attempted the Microsoft Fix it 50339 and was told that I did not hav ethe correct software or OS for this fix.
E Outlook 2010 network printing problems Using Outlook 4
D Outlook 2010 unable to use mail when in home wireless network. Using Outlook 3
