Rule problem: Delete message(on other machine)
JimVag
I have set a rule for a message. This rule is that when a specific message arrives it will be permanently deleted and i have set also that this message applies for "this message".
The problem is that despite that, this rule, in the list of rules displayed, has in brackets that it is "for other machine".
I suppose that this problem is caused because the other day i imported the pst file from another pc for which i had created exactly the same rule. So, in 2 PCs i have exactly the same rule and in one of them i imported the pst of the other and consequently the rule( i suppose) in the pc that "accepted" the pst file was altered to "ohter machine".
Ok, suppose things happened described as above-i have tried repeatedly to alter this to "this machine only", instead the rule is listed with the "for other machine" message in brackets beside it.
Any ideas why this happens?
Russ Valentine
When you migrate rules you must reset them to the new location before they will work. Just step through the rule so it will be connected to your current file's location.Russ Valentine
L Rule problem Using Outlook 4
L Making rule to move email to folder from one O365 domain Using Outlook 1
Ascar_CT Rule behavior analysis - any tools available? Using Outlook 0
Liza Creating a rule in outlook to filter messages Using Outlook 0
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
B custome rule Outlook VBA and Custom Forms 2
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
Diane Poremsky Run a Script Rule: Send a New Message when a Message Arrives New Slipstick.com Articles 2
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
C Rule To Save attachments on receipt of email Outlook VBA and Custom Forms 2
Diane Poremsky Create a Task from an Email using a Rule New Slipstick.com Articles 0
M Rule option Using Outlook 2
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Transactional emails - mail rule Using Outlook 3
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
