Voting Buttons are Not Tracking
susana123
I used Tracking of Voting extensively in Outlook 2003 and also had rules setup in Outlook 2003. It always worked in Outlook 2003. I recently moved to Outlook 2007 and setup the same rules. These rules don't move the original voting email from my sent and they don't move the responses out of my inbox. I have Outlook SP2. The tracking sometimes work if I specify custom voting options and must specify at least 3 voting options. I have not been able to track anything with only 2 voting options.
Does anyone know what else I can check or install?
Forum Admin
If you move the item from the sent folder, the votes won't talley. If you turn off the rule, tracking should work better.
Note that if the TNEF data blob is lost from the reply, the votes won't talley. This can happen if you scan email with an antivirus scanner.
F Stationery with Voting buttons Using Outlook 9
P VBA create mail with attachment and voting buttons Using Outlook 6
P Voting buttons not showing Outlook VBA and Custom Forms 1
S HELP: Add logic to what Voting buttons do Outlook VBA and Custom Forms 1
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
C Voting Issue with Shared Inbox Using Outlook 1
R How can I retain embedded object with voting button reply? Using Outlook 5
T Voting and auto reply Exchange Server Administration 3
H Issue with Custom Voting options Using Outlook 3
S Outlook Email Help: Select custom voting button options VBA Outlook VBA and Custom Forms 1
I Ribbon buttons grayed-out in Outlook 2013 Using Outlook 2
R Custom buttons for frequently sent to reciopients, OL 2010 Using Outlook 1
R Outlook 2007 QAT buttons not saving Using Outlook 2
H enable textboxes and buttons from received email Using Outlook 1
Commodore Back/Forward toolbar buttons with pull-down history? Using Outlook 5
T Textarea and Radio Buttons in Outlook Email Using Outlook 1
D Re: How do i insert radio buttons in an email Outlook VBA and Custom Forms 1
S Catch events from pre-existing buttons in Outlook 2007 Outlook VBA and Custom Forms 7
S How to Create Buttons in email body / toolbar Outlook VBA and Custom Forms 3
S HELP: Create Buttons in Outlook Email body or Tool bar Outlook VBA and Custom Forms 1
K Buttons are added multiple times in New Inspector window Outlook VBA and Custom Forms 4
S inspector toolbar buttons get multiple events Outlook VBA and Custom Forms 3
G Custom Buttons Disappear Outlook VBA and Custom Forms 1
M Radio buttons and checkboxes Outlook VBA and Custom Forms 2
S design buttons in email body Outlook VBA and Custom Forms 1
F Possible to restore/reinstall "special" buttons on custom form? Outlook VBA and Custom Forms 1
T Multiple Toolbars being added/Multiple Buttons being added to Mail Outlook VBA and Custom Forms 5
C Tracking Calendar Changes? Using Outlook 1
H tracking time of emails Outlook VBA and Custom Forms 2
N Tracking Mail items being moved to folders Outlook VBA and Custom Forms 5
N Activity Tracking with Userform Outlook VBA and Custom Forms 4
S My Draft Emails Have Review Tracking Using Outlook 7
rino email campaign - tracking opened emails Outlook VBA and Custom Forms 6
D tracking emails in outlook 2010 Using Outlook 1
C Rule to Handle Meeting Replies that updates tracking information Using Outlook 2
M Room Reservation request showed "None" in Tracking-View Tracking Status. Exchange Server Administration 0
C Tracking WHO deleted items in a Shared Mailbox Using Outlook 1
S How to remove tracking from printing - outlook 2010 Using Outlook 4
J Tracking sent emails Using Outlook 3
R Can't use "manage linking and tracking" BCM (Business Contact Manager) 10
