Completely wipe all Outlook-related info for reinstall
Installing Outlook 2010 has problems. Uninstalling and reinstalling doesn't help, because Outlook remembers previous actions, including profiles and folders, and simply puts everything back the way it was the last time. Which makes reinstalling unusable. And reloading the only option. Or going to a competitor.
Did you delete the profile in control panel, Mail ? Unistalling doesn't delete user data or profiles- you need to do that yourself.
Victor_50 Outlook 365 Quick search by period (today, yesterday, last week) completely missing in newest OL 365 Using Outlook 0
D How do I start completely from scratch in setting up Outlook 2013? Using Outlook 6
J Outlook client not redrawing completely upon restore Using Outlook 0
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
I How do I completely delete contents of "deleted items" to reduce pst file size Using Outlook 1
P VBA Code being completely ignored by Outlook Using Outlook 7
B How to completely and permanently deleting a POP3 Account in 2010 Using Outlook 9
L how do I remove business contact manager completely? BCM (Business Contact Manager) 1
S Calendar updates wipe out personal notes. Using Outlook 3
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 10
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 5
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 11
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
G Outlook translation feature is off Using Outlook 2
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
J Outlook troubleshooting/logging - option grayed out Using Outlook 2
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Outlook 2021 (New) doesn't respect default browser Using Outlook 9
B Outlook or iPhone turning tabs into spaces in Outlook Notes Using Outlook 1
P newly installed Office 365 includes OLD Outlook Using Outlook 6
R Outlook ribbon menu default? Using Outlook 7
H Spam email in Gmail not visible in Outlook Using Outlook 3
J How to transfer Win 10 Outlook to new Windows 11 pc? Using Outlook 16
G Reduce whitespace in Outlook desktop Contact Cards display Using Outlook 3
C Outlook classic via 365 Using Outlook 2
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
S Repair Outlook Using Outlook 8
V Outlook Form ListBox is not editable Outlook VBA and Custom Forms 2
F Outlook's contacts Using Outlook 1
D Outlook 2003 stopped dead Using Outlook 2
G Cannot receive emails from gmail account in Outlook 365 Using Outlook 1
P Outlook 2016 Working Offline Using Outlook 2
Rupert Dragwater Cannot reestablish gmail (email address) account in Outlook 365 Using Outlook 11
O Outlook 365 synchronisieren Exchange Server Administration 1
