Forwar email not using default account
I have outlook 2007 when I forward some emails it does not use default email address
it uses second address I have in outlook
e.g. The recipient would see it was from other email address that’s not the default
I could change this using the account drop down to select, but I don’t want to check this every time
Forum Admin
Which account downloaded the message you forwarded? The account that downloaded it should always forward a message.
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
HarvMan Archive Email Manually Using Outlook 1
Rupert Dragwater Duplicate email in Folder Using Outlook 7
MattC Changing the font of an email with VBA Outlook VBA and Custom Forms 0
L Specific Incoming Email Address Immediately Deleted Using Outlook 2
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
R Roadrunner Email Settings | Contact Roadrunner Customer Support Outlook VBA and Custom Forms 1
Albert McCann Outlook 2021 Outlook Display of HTML Email from two senders is glitchy Using Outlook 0
A How Do I Setup My Optonline.Net Email Account? Outlook VBA and Custom Forms 1
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
D multiple email accounts - why do I have to choose the "from" account address?? Using Outlook 2
F Outlook 2016 Email with attachments not being received Using Outlook 3
J Outlook 2019 Regex email addresses from body Outlook VBA and Custom Forms 6
D Prompt to prefix subject line whenever sending an email Outlook VBA and Custom Forms 3
C Wishlist Extract or scan new email addresses from out of office replies. Leads from OOO replies Using Outlook 1
T External email warning banner Outlook VBA and Custom Forms 0
A Links in email getting error message about group policy Using Outlook 4
J Recommendations for Outlook Duplicate Email Remover Using Outlook 6
Geldner Tweak Junk Email Reporting tool to default to particular email on send? Using Outlook 3
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
P default font when sending email from browser Using Outlook 1
B IMAP server rejects sent email - cannot deliver messages Using Outlook 2
C Email bomb processing Outlook VBA and Custom Forms 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
