Contacts & birthdays
Commodore
Outlook 2021 64 bit
I've noticed that Outlook 2007 sets reminders on birthdays (at least those that were created after installing 2007). Is there any universal way to turn all of them off? I've had quite a heritage of contacts in here, from around 1997 on. Birthdays of the newly entered ones appear to be categorized and colored (which is fine), and have reminders (which can be annoying). As for the older ones -- I found some of them were duplicated or even moved one day backward or forward (I'm guessing due to some inconsistencies with Pocket Outlook syncing in the first or second version of Windows CE, and the dreaded daylight savings/waste switching), so there is a chance some of them aren't even correct anymore. :S
Is there a relation from the birthday back to the contact entry at all (or is it "create and forget") -- so that removing or changing a contact's birthday reflects the change in the calendar as well (I have the feeling it only creates a duplicate entry)?
Forum Admin
Removing reminders is fairly easy using a group by view. Add the Reminder field to a List view, group by it and drag the items with reminders: yes to the Reminder: No group.
Once Contacts create the birthday appointment, its disconnected from it, so changes in the contact will result in a duplicate. If you delete the birthday appointment, outlook shouldn't create a new one unless you edit the contact.
S Outlook.com birthdays show up 1 day late on iPhone contacts list Using Outlook.com accounts in Outlook 27
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
R How to prevent corrupted Notes format in Calendar and Contacts Using Outlook 0
kburrows Outlook or Phone Combining Contacts? Using Outlook 0
S Cannot print Contacts Using Outlook 7
L Favorites for People/Contacts? Using Outlook 1
F Moving Contacts to New Profile Using Outlook 0
V Contacts in O365 have changed?? Using Outlook 20
GregS Exporting contacts Using Outlook 1
egarneau Meeting updates with external contacts (GMail) Using Outlook 1
bhamberg Contacts in a category Outlook VBA and Custom Forms 11
