AutoArchive in 2010 not working
eliszt
In Outlook 2010:
When running a "Archive all folders according to their autoarchive settings", no messages get moved to the archive PST.
When using the manual archive method of setting a date for a specific folder and running it, messages ARE moved.
I've added the "modified date" and "Do not auto archive" flag to the view and I can see that the date is indeed older than the auto archive setting of 1 week. I can also see the flag is not set.
I'm flummoxed here. Anyone got a suggestion? Version 14.0.5128.5000 (32 bit)
larry
There was a hotfix released last week - http://support.microsoft.com/kb/2475877 - i thought i read somewhere that it addresses some archive issues but i don't know if it applies to this exact problem though. (the kb article doesn't mention archive issues - i don't know if the other infomation i have is correct).
eliszt
Thanks, Larry. Yeah... nothing in that one regarding Archive. I'll keep looking for a solution. Hopefully something will come along soon.
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
Diane Poremsky Using Outlook's AutoArchive Feature Using Outlook 0
E Moving autoarchive settings to new computer (Outlook 2007) Using Outlook 1
K Revert AutoArchive settings via GPO (Run Autoarchive every...) Using Outlook 4
B AutoArchive Nuances Using Outlook 1
K Autoarchive when contradicting company policy Using Outlook 3
R Get AutoArchive settings (as set from Tools|Options|Other|AutoArch Outlook VBA and Custom Forms 1
B Update AutoArchive Settings on Multiple PST Files Outlook VBA and Custom Forms 5
M Can't change autoarchive property in Deleted Items folder BCM (Business Contact Manager) 1
M Upgrading from: MS Office Professional Plus 2010 to: MS Office Professional Plus 2021 Using Outlook.com accounts in Outlook 16
T Outlook 2010 Cannot edit Calendar entries in OL 2010. Using Outlook 1
F how do i set a reminder in onenote 2010 Using Outlook 8
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 3
Witzker social connector 2010 does not show all emails to or from contact Using Outlook 0
