Opening Calendar Foreces Shutdown
I use Outlook for work and I have multiple company calendars that I use for scheduling throughout the co. Sometimes I can open more than one calendar and see/ edit them both. Usually, however, opening more than one calendar will force Outlook to shutdown completely . I'm told this is a problem specific to Outlook and shouldn't be related to our server, etc...
Any thoughts to why Outlook would shutdown like this?
Brian
Forum Admin
Check the Windows Event viewer - does it have any errors listed for outlook or the crash?
I'd try two things - restart outlook with the /cleanreminders switch and if it still crashes, use the /cleanviews switch. Note that cleanviews will wipe out all custom views.
KurtLass Opening Graphics Attachments in Outlook 2021 Using Outlook 0
Witzker Place cursor at opening, a user defined OL contact form Outlook VBA and Custom Forms 3
A OutLook For Mac 16.46 Comes Up In Small Window When Opening Using Outlook 4
U Disable "Always ask before opening" Dialog Using Outlook 3
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
B Outlook 2010 Opening Mail Attachment Using Outlook 2
A Warning When Opening attachment Using Outlook 7
A Outlook 2016- unable to have all subfolders expanded when opening outlook Using Outlook 11
GregS Immediate crash on opening Using Outlook 3
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet Using Outlook 0
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
J Opening Attachments - in People Using Outlook 2
Mistyfied Outlook 2016 not opening Using Outlook 2
M Update field codes when opening Outlook Template Outlook VBA and Custom Forms 2
R Outlook PST not opening Using Outlook 1
U .pst file error at opening outlook Using Outlook 1
Diane Poremsky Disable the Unsafe Hyperlink Warning when Opening Attachments Using Outlook 0
S macro for opening attachments and printing Using Outlook 1
Z how to make OL (2007) to use custom contact form when importing / opening .VCF? Using Outlook 1
T Opening email causes "Contacting ..." message Using Outlook 1
K Outlook 2013 stuck "processing" when opening. Using Outlook 3
S Opening Outlook Windows Using Outlook 1
S PoP up reminder while opening the outlook? Outlook VBA and Custom Forms 1
J Opening/Archiving/Import/Export PST files Using Outlook 4
Y (Shared Folder) Using the preview pane to open and close a fax, without opening the email itself Using Outlook 1
E OL2007 on Exchange: opening OL on different computers Using Outlook 1
Z outlook 2007 - opening a contact from the search results doesn't use the custom form Using Outlook 10
T Error opening mail with pictures - "The linked image cannot be displayed" Using Outlook 3
P I'm getting an error when opening Outlook "Mobile me stopped working Using Outlook 1
D opening Word Document in a business contact? BCM (Business Contact Manager) 3
B Contact changes from Personal to Shared when opening custom form Using Outlook 0
C How to stop iCloud calendars opening by default Using Outlook 8
U outlook 2010 freezes/crashes when opening encrypted e-mails Using Outlook 0
G OLMAPI32.dII error prevents Outlook 2010 from opening Using Outlook 2
D Custom Tool Bar and/or Commands do not remain when re-opening Outlook 2007 Using Outlook 3
G opening Outlook again after closing closing? Using Outlook 0
B Outlook 2010: how to mark messages without opening? Eg for deletion Using Outlook 2
M I cannot start Microsoft Outlook 2013 directly opening a .eml message Using Outlook 1
M Opening Word Doc's in Adobe Acrobat Pro Using Outlook 9
L Opening up Contact from an Email - Outlook 2007 Using Outlook 15
G Opening messages takes too long Using Outlook 5
G Opening pst files in different versions of outlook Using Outlook 2
F Default Program for Opening .pst Files ? Using Outlook 6
