Syncing preferences/settings across multiple machines
hopsj
Hello -
Has anyone had success either storing their settings/preferences on a network drive or at least syncing settings/preferences across multiple machines on a LAN? I find it so annoying to have to recreate all of my preferences and open my outlook data files whenever I log onto a new machine.
Cathy Rhone
Outlook 2013 32 bit
Exchange Server 2010
You can create a PRF to to set up the profiles and add pst files to it. You can export settings from the registry. I don't recommend exporting the profile from the registry as it may reference files in specific locations and addins that may not exist on each computer.
See http://www.outlook-tips.net/howto/prf.htm for infomation about creating a prf.
If you use an active directory network, you could use roaming profiles but this works best if the systems are all identical save for the computer name.
P Syncing Outlook & iPhone Calendars Using Outlook 4
e_a_g_l_e_p_i Can someone explain syncing with Outlook and Gmail Using Outlook 3
TomHuckstep Outlook 2016 Limit the number of days syncing from Google Calendar Using Outlook 1
F My hotmail calendar is not syncing with my outlook but my email is Using Outlook 3
T Outlook 2010 Advice on syncing OL2010 Calendar and Outlook app Using Outlook 0
M Quicken One Step Update Bill Reminders Not Syncing to Outlook Using Outlook 1
C Syncing on outlook.com Using Outlook 4
T Syncing to Android Phone Using Outlook.com accounts in Outlook 4
H Syncing Outlook notes with ios Using Outlook 3
A added new calendar, now not syncing to windows phone Using Outlook 3
S Outlook User defined date field (UDF) not syncing Using Outlook 2
F Contacts folders not syncing with hosted exchange Using Outlook 3
Diane Poremsky Syncing Outlook with an Android smartphone Using Outlook 0
Charles Brooks SEES Exchange not syncing with win 10 calendar. Exchange Server Administration 0
R Outlook 2016 not syncing all folders Using Outlook 1
M Outlook 2016 - Mail Not Syncing With iPhone Outlook App Using Outlook 1
A windows mobile 10 calendar not syncing Using Outlook.com accounts in Outlook 0
B Syncing Office 365 folders to match Outlook 2013 Using Outlook 3
B Contacts just stop syncing, yesterday... Using Outlook 4
J Outlook 2013 Syncing contacts with Android phone - Outlook.com vs Outlook apps Using Outlook.com accounts in Outlook 4
K Outlook 2007 IMAP account stops syncing new messages Using Outlook 0
T Not all contacts are syncing Using Outlook.com accounts in Outlook 2
K Outlook 2013 Outlook 2013 no longer syncing 1 of 5 IMAP accounts Using Outlook.com accounts in Outlook 0
G Outlook 2013 not syncing changes to outlook.com account calendar? Using Outlook.com accounts in Outlook 8
I Outlook Contacts and Calenders not syncing between PC, IPhone, and Windows 8.1 tablet Using Outlook 3
Commodore Syncing Outlook 2013 and Windows phone Using Outlook 8
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
V iCloud not syncing categorized calendar events Using Outlook 7
B Outlook.com calendar no longer syncing with Blackberry Using Outlook.com accounts in Outlook 5
T Syncing iPhone w/Outlook Using Outlook 1
VCC Icloud/Outlook Syncing Issues Using Outlook 1
Marcy Outlook and SharePoint 2013 - Syncing Contacts Using Outlook 2
A outlook 2013 not syncing Using Outlook 1
D Outlook 2010 contacts syncing intermittently via Outlook Connector Using Outlook.com accounts in Outlook 2
V Outlook not syncing with iCloud Using Outlook 5
I Different users connected to an IMAP email aren't syncing with each other Using Outlook 5
A How are you handling Outlook.com category issue and syncing Using Outlook.com accounts in Outlook 2
mariobgr Syncing locations in calendar Using Outlook 1
