Removing time zone setting from an appointment / meeting: is it possible?
tfboy
If I create an appointment, I can set a time zone I want the time to be at. That's fine.
However, I cannot remove a time zone value from an already-existing appointment. When I click on the time zone button, the button remains "pressed" and there's no way of removing the setting.
I'm normally in GMT and it's a real pain for things like birthdays or bank holidays which are annually recurring all-day events: when I'm in a different timezone, the meeting spans over two days as it's offset.
Is there any way to remove the time zone setting for these or do I have to delete and recreate them all with no time zone setting applied?
It seems like a simple thing yet it's driving me nuts!
Thanks in advance :)
Forum Admin
First off, learn to live with it for short term changes. Ie, if you are traveling for business or pleasure, don't change the all day events. (Use dual time zone display in outlook and you can see events in both your home and visiting zones.)
If you move to a new time zone, you have two options- export to Excel while set on the old zone, change zones, delete the all day events (use a list view), and import. (You'll also want to delete appointments from the excel sheet that don't need to be changed before importing.) Or get the time zone mover tool and let it move the apointments for you.
Time zone mover tool: http://www.microsoft.com/downloads/...33-b9c8-4652-9dd8-ae0f1af62568&displaylang=en
tfboy
Thanks. So short answer is "no" then! :( and thanks for the suggested workarounds
D Question on removing an alias Using Outlook 1
G Removing old emails when adding accounts Using Outlook 3
R Outlook is NOT removing attachments. Using Outlook 4
B Removing Recipients from an automatic response Outlook VBA and Custom Forms 2
O How to paste website content using a specific font and removing URLs Using Outlook 2
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
A Removing illegal characters Outlook VBA and Custom Forms 2
D 'removing' an e-mail folder Using Outlook 2
G Wrong display name in from column when removing pf replication Exchange Server Administration 1
S Removing an Exchange Server account, retaining POP accounts Exchange Server Administration 1
D Removing Pop3 accounts on mulitple computers Using Outlook 3
K Removing outlines from outlook calendar Using Outlook 1
L Outlook 2007 - How to remove account without removing mail folders? Using Outlook 4
R What to backup before removing Outlook 2010? Using Outlook 4
V Outlook problem after removing avast Using Outlook 1
P Removing expired e-mail addresses Using Outlook 2
D Removing multiple Exchange 2007 servers on the same Domain and site Exchange Server Administration 1
S Removing myself as delegate from someone else's calendar Using Outlook 1
C removing "Microsoft "End-User License Agreement" window BCM (Business Contact Manager) 1
S Removing "Research" menu item Outlook VBA and Custom Forms 1
H removing attachments... Outlook VBA and Custom Forms 1
M Calendar Time Zone issue Using Outlook 0
P Outlook 2013 to Outlook.com Time Zone sync Using Outlook 4
A Calendar time zone Using Outlook 1
Diane Poremsky Use VBA to get an Appointment's Time Zone Using Outlook 0
J Calendar Appointments move when Computer Time Zone changed. Using Outlook 5
M Time Zone Problems with Internet Calendar Using Outlook 20
B Outlook Calendar - Time zone changes after the meeting request is accepted. Using Outlook 1
D Outlook 2007 Reminder Times Change When User Changes Time Zone in Date/Time Using Outlook 4
M Calendar Time Zone Issue Using Outlook 4
J Outlook's auto time zone update for meeting requestsHow to REMOVE or DISABLE? Using Outlook 1
AlphonseG Outlook 365 Outlook Crashes on setting SaveSentMessageFolder Outlook VBA and Custom Forms 5
Marc2019 Setting up an Outlook Account on Mac Os 10.6.8 Outlook 2011 Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
B Setting rules Using Outlook 1
B Setting defaults Using Outlook 2
