EML to VCF Conversion
chome4
Older version
How do I convert EML files to VCF?
Hope someone can help.
I don't think you can - EML is email file type, vcf is vcard.
How did vcards get converted to eml? Is their structure intact? (look at it in notepad) - if you see BEGIN:VCARD
VERSION:2.1 and lines with the name etc,, ending with END:VCARD, you can use a batch file to change the extension to vcf.
J convert .pst to .eml, how is it possible? Using Outlook 1
T To: and Cc: not displaying when forwarding/replying to .eml files Using Outlook 4
M I cannot start Microsoft Outlook 2013 directly opening a .eml message Using Outlook 1
J bug in converting eml files of wlm on import to outlook 2010 Using Outlook 7
A Importing eml files into outlook 2007 Using Outlook 3
H Drag and Drop Outlook mails into a Windows Form Control with eml extension Outlook VBA and Custom Forms 1
K importing EML in MailItem Outlook VBA and Custom Forms 1
Z how to make OL (2007) to use custom contact form when importing / opening .VCF? Using Outlook 1
Glyn Vcard multiple or Single .vcf's Using Outlook 3
R How do I move .vcs and .vcf files on to my new SSD from my old HDD Using Outlook 1
D cant open vcf file Using Outlook 1
Commodore Exporting all contacts to VCF files possible? Using Outlook 4
L Importing multiple record from .vcf (vCard) file Using Outlook 5
K How to copy Contact Item to Clipboard and Paste as "VCF Link? Outlook VBA and Custom Forms 4
K GroupWise to Outlook 2013 conversion: Tasks Using Outlook 0
Jennifer Murphy Distribution list fails after conversion to Unicode PST Using Outlook 2
Jennifer Murphy Questions about ANSI-Unicode PST conversion article Using Outlook 2
P Auto-conversion mail to task Using Outlook 6
3 Outlook 2007 and file attachment conversion Outlook VBA and Custom Forms 3
T RE: ACT to BCM Data Conversion BCM (Business Contact Manager) 1
K ACT!/OUTLOOK BCM CONVERSION BCM (Business Contact Manager) 2
