Junk Folder not operating
My 2007 Junk folder stopped working, meaning spam is not going to the folder. All spam comes to my inbox now. I cannot open the Junk Folder in a new window. When i try to open the folder in a new window, the error is "cannot display information. There is either a problem connecting to the server or an error occurred".
I do not have an exchange server.
When i check the folder size (1183 messages show), in "Properties", the size reads as "<error>".
The other error during opening the window is "The messaging interface has returned an unknown error".
I have restarted the PC and Outlook numerous times.
I have not made any changes to the software, this has happened not in connection with any changes.
I use Lunar Pages as my mail server and i have not made any changes there.
Any help is greatly appreciated. Thanks :)
larry
Close outlook and restart it in safe mode. You can hold ctrl as you click on the Outlook shortcut to start up in safe mode. Does it work ok? If so, what addins do you have installed?
It's possible the view on the junk folder is corrupt. You can reset the views (will remove all custom views) using the cleanviews swtich.
In the Start menu, search field or Windows key+R to open the Run command, type
outlook.exe /cleanviews
and press enter. Note, there is a space between outlook.exe and the /.
Thanks so much, Larry. Later, the .pst stopped working. i used the scanpst.exe file and this solved the problem.
I really appreciate you taking the time to make your suggestions. :eek:
Christopher M Outlook 365 Hey Diane! MS 365 Biz Standard and "Potential Spam" addressed to others coming to my JUNK folder? Using Outlook 2
T Probem with junk mail folder in new account in Outlook Using Outlook 0
M junk mail folder Using Outlook 2
K Emails stuck in 'Junk' folder Using Outlook 0
David Rahrer Change default Junk E-Mail folder Using Outlook 6
L My junk email folder has disappeared - Using Outlook 0
V Macro to view Junk Email folder Using Outlook 4
V Emails going to Junk folder Using Outlook 2
U Problems with junk mail folder... Using Outlook 1
R Emails suddenly going to the Junk email folder Exchange Server Administration 3
G Red crossed circle disappeared from Junk Mail folder Using Outlook 3
E Can rules be applied to the Junk E-mail folder? Using Outlook 2
R How to remove or move the default Junk e-mail folder BCM (Business Contact Manager) 3
T Outlook add-in: How to find localized name of the "Junk e-mail"folder Outlook VBA and Custom Forms 15
J How to Block junk/spam domain Using Outlook 0
P What is your strategy for dealing with SPAM and Junk Mail? Using Outlook 1
Geldner Tweak Junk Email Reporting tool to default to particular email on send? Using Outlook 3
J how to stop junk emails from *.onmicrosoft.com ? Using Outlook 2
I Junk Mail and PersonMetadata Using Outlook 2
F Outlook 2016 Junk E-Mails Using Outlook 5
J Junk mail doesn't work Using Outlook 3
T New Account Shows No Junk Mail Folfer Using Outlook 0
C Why can junk mail be from one’s own email address? Using Outlook 7
Diane Poremsky Junk Mail Filtering in Outlook Using Outlook 0
S Outlook.com - Junk files Using Outlook.com accounts in Outlook 1
R Not junk email Using Outlook 3
lotsbg Loads of junk in second email needs fixing Using Outlook 1
7 Macro to mark message as junk and delete Outlook VBA and Custom Forms 3
G filtering email with missing TLD to Junk Outlook VBA and Custom Forms 1
R Outlook - alternatives to Rules / Junk? Using Outlook 5
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
R Outlook 2007 junk mail Using Outlook 4
mrje1 Junk Options - Safe Lists not working. Using Outlook 0
C Outlook 2013 Junk Mail Filters Using Outlook 0
Commodore Junk Mail filtering and IMAP Using Outlook 3
D Junk Mail filter Using Outlook 1
J Junk email Exchange Server Administration 1
A Junk mail Using Outlook 4
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
C starting Outlook 2003 sp3 sets Junk Email setting to 'No automatic filtering' Using Outlook 3
