(Read, not read) receipt "subject" problem
caprilr2003
Dear all,
Thank you for accepting me, I hope I could you use your vast experience.
I run 2 PCs 1 X vista32 and 1 X XPSP3, both with outlook 2007, in English and Greek language. To be updated (and some short of sync), both PCs are running the same email accounts, so whatever comes and go from and to are, is twice stored.
All accounts, mixed POP and IMAP, are set to ask for sent/read receipts which works smoothly when the "subject" is in English language...meaning that when I receive "read/ not read" receipt from "myself" the subject when in English appear readable but when is written in Greek language it is not.
I have tried several "adjustments" (trial and errors) to Mail Format/international options with no luck, but I feel that I'm close...
I appreciate for considering my query,
Alexandros
caprilr2003
Thank you for your prompt reply,
Yes both PCs are running relevant language pack for English and Greek BUT XP Windows are in Greek and Outlook in English (see picture), while Vista is English 100%
I'm checking with some people to see if anyone knows what is going on.
I'll have to ping my language experts again. To clarify, when the subject is messed up, is it messed up on both computers?
If they were messed up by the sending client or server, you can't fix them on your end. But if they are messed up on one computer but not the other, you might be able to fix it.
caprilr2003
Dear Mrs. Poremsky,
The problem occur only to Vista desktop, XP sends and receives as should. This happened after twisting ("trial & error" method) settings in XP's/mailing "en-coding" (file attached before). But the same configuration is not providing the same results in vista.
Should further info required pls dont hesitate to ask for,
kind regards,
Alexandros
S Duplicate Read Receipt Using Outlook 4
G Editing the Read Receipt Using Outlook 1
S Block read receipt when outlook is configured to Exchange server Using Outlook 0
R How to auto reply with read-receipt Outlook VBA and Custom Forms 2
W Read Receipt Requested Outlook VBA and Custom Forms 1
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
M TO field on Read Page not resolving Using Outlook 3
G How to make outlook show as unread messages I read in my mobile ph or tablet Using Outlook 1
