Combo Box
LMS
I used the same macro name for all three just to see what shows up....
So where do I test it? As under the VBA area and I hit run, the combo box shows up but nothing in the downlist......
Since these macros listed only work when I click on a contact, how should I open up the userform combo box in a contact or after identifying the contact, and see what happens?
Make sense?
Here is the code per what you gave me as I posted the macro you can see earlier so you see the name etc.
Public lstNo As Long
Public Sub NewMessageUsingTemplate()
Dim oMail As Outlook.MailItem
UserForm1.Show
Select Case lstNo
Case -1
From_Lou_Stoler
Case 0
From_Lou_Stoler
Case 1
From_Lou_Stoler
Private Sub ComboBox1_Change()
Did you also add this to the userform?
Private Sub UserForm_Initialize()
cbList.AddItem "Potential client"
cbList.AddItem "New client welcome letter"
cbList.AddItem "Work order approval"
cbList.AddItem "Existing client"
cbList.AddItem "Payment overdue"
cbList.AddItem "Invoice"
Private Sub btnOK_Click()
lstNo = cbList.ListIndex
Unload Me
LMS
I did not. What area or part of the code do I put it, and as to each cb.ist.AddItem , should the words inside " " be the macro names?
Thanks very much. Will be excited to get it done.
And also, how do we create the button to the contact form so it open up the userform?
Thanks again so very much!!!
BTW, That is probably a bad example - that is from a macro I did with different variable names.
Make sure the name of the sub that adds the items is called
The click macro will be the name of the button control, CommandButton1 by default.
LMS
As a favor, please add to or change the code below what needs to be added or changed and where to put it. As again, I am not the expert!! Thanks so much. I truly appreciate your support!!
UserForm1.Show
Select Case lstNo
Case -1
From_Lou_Stoler
Case 0
From_Lou_Stoler
Case 1
From_Lou_Stoler
Private Sub UserForm_Click()
This is not used:
This goes in the userform with the userform_initilize routine.
Private Sub CommandButton1_Click()
lstNo = ComboBox1.ListIndex
Unload Me
This goes into a module - because everything is being done in the other macros, you only need this much.
UserForm1.Show
Select Case lstNo
Case -1
From_Lou_Stoler 'macro name
Case 0
Case 1
I uploaded a video to youtube - the first minute shows how to set macro security - you can start it about 1 min.
Outlook Userform and Combo boxes - YouTube
LMS
Thanks very much as usual. Please see below and tell if this is correct?
And also, I have other combo boxes so the new one will be ComboBox7......that's ok ...correct?
And again , answer the above and review below so I can get this done right away.
And thanks so much
So the code of the UserForm1 is just:
Unload Me
And I create a new module which is just:
UserForm1.Show
Select Case lstNo
Case -1
Case 0
Case 1
No, the code in the userform is not just the commandclick. you need to initialize it and set the list in the dropdown -
With Combox7
.AddItem "Invoice"
If you are using multiple comboxes, you need to make sure the code points to the right one - so in #7, it will be
lstNo = ComboBox7.ListIndex
Unload Me
LMS
So this is the code I created and just have two .AddItem and i put in the name of each of the two macros....is that correct?
With Combox7
.AddItem "From_Lou_Stoler"
.AddItem "From_Lou_Stoler_and_Vcard"
Unload Me
And this is the Module....is this correct?
UserForm1.Show
Select Case lstNo
Case -1
Case 0
From_Lou_Stoler_and_Vcard 'macro name
LMS
And the commandbutton as the new one is commandbutton4....and I changed that
LMS
Did you review the codes I showed you? and those should work?
And how do I create the click to the userform in the contact tempate
I add a combo box and a command button and they are numbers i gave you, but nothing shows up on a list ..
As to each one it askes to assign it to a field? How do I do that, or just create shortcut to the userform?
Hopefully there is an easy way to do it....
Thanks so much for your continuing help!!!
you have an easily missed typo in Combox7, but with that fixed, it works here.
I used this code in the module. if the macros are in other modules they need to be public - private can only be called from the same module. to keep the index in the correct order, you need 0 and 1, plus -1.
When i run it, a msgbox pops up with one of the macro names.
UserForm1.Show
Select Case lstNo
Case -1
Case 0
Case 1
Private Sub From_Lou_Stoler()
MsgBox "From_Lou_Stoler"
Private Sub From_Lou_Stoler_and_Vcard()
MsgBox "From_Lou_Stoler_and_Vcard"
Video of this in action 01.28.2013-12.08.24 - dicot's library
LMS
How do I run the userform thru a contact to see if it works: and see below:
This is the userform1:
With Combox7
Private Sub CommandButton4_Click()
Unload Me
This is the Module
UserForm1.Show
Select Case lstNo
Case -1
Case 0
Case 1
To use it with select contacts, you need to add and if then statement:
'whatever
in this sample, it would be
' This will work with macros in a different module.
' Normally this is inside the sub as Dim oContact As Outlook.ContactItem
' and only works with the it is in.
Public oContact As Outlook.ContactItem
If TypeName(ActiveExplorer.Selection.Item(1)) = "ContactItem" Then
Set oContact = ActiveExplorer.Selection.Item(1)
UserForm1.Show
Select Case lstNo
Case -1
Case 0
Case 1
End if
Set oContact = Nothing
LMS
I don't understand again.....
can you simply take my codes I gave you, and changes each one from the beginning to the end, so I can copy and paste them and see what happens
LMS
Here is the full summary of everything so hopefully you can show what to fix, and where.
I have the special macros that refer to an email template and when I click on a contact or open it, and run the macro, it automatically creates the e-mail from the template described in the macro, and automatically adds the e-mail address of the contact to the To bar of the e-mail.
In order to create a dropdown list of the macro's inside the contact template form, I did the following:
Under Project1 of the Visual Basic Editor, I created a new UserForm1 where I added a CommandButton4 and the Caption is "E-mails From Lou" and I added a ComboBox7 and the code of the ComboBox7 is:
With Combox7
Unload Me
I added a new Module7 and the code is:
UserForm1.Show
Select Case lstNo
Case -1
Case 0
Case 1
So the question is how to show the combo box list of macros per the codes of the UserForm1 and Module7?
I opened up the contact template, opened up the VBA, and copied and pasted to the contact template the commandbutton4 and the combobox7, and published the form so it shows up in all contacts, but no drop lists re the macro's show up under the combobox7. And as to the combobox7 in the contact, I created a new text field as it requires to have field.
Is there a way to finally fix this so I can see the dropdown list of the macros in the combobox?
With Combox7
Unload Me
You have a typo/misspelling that needs fixed. It should work after that.
LMS
Can you show m what the type/misspelling words etc are.....i don't know what needs to be fixed.....thank you so much.....I am confused about the words..
LMS
And again, as a reminder, I am not the expert and just rely on what you have showed me to type in the whole time. So if you can copy what I posted of both codes, change them as needed, and post them back, I will copy and past to my computer, as I don't know what to fix.
And again, as well, I so appreciate your support. It's been the best forum I have ever used!!!
P Custom Outlook form_Validations in combo box Outlook VBA and Custom Forms 0
S Outlook form - Combo box for deciding who to send form to Using Outlook 1
M details with the combo box Exchange Server Administration 3
Q Follow up: Make a combo box dependant on another Outlook VBA and Custom Forms 6
Q Make a combo box dependant on another Outlook VBA and Custom Forms 5
Q Load a recipient based on a value in a combo box Outlook VBA and Custom Forms 7
F Outlook 2010 - outlook userform and combo boxes Using Outlook 9
M Need help with combo boxes in messages! Using Outlook 10
T Outlook 365 Search Box reverting to old location Using Outlook 3
A GetSelectNamesDialog Pre-fill search box Outlook VBA and Custom Forms 12
K Sharedmail box Outlook VBA and Custom Forms 4
Diane Poremsky Outlook Suggestion Box at Uservoice Using Outlook 0
D Emails do not appear in Sent box! Using Outlook 4
Kristine RS box added in Favorites disappears Using Outlook 6
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
Ross Garvey Dialogue box opens as I exit Using Outlook 2
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
G Enter Network Password box pops up every few seconds Using Outlook 2
V In Box Issues Using Outlook 1
S Custom yes/no message box. Using Outlook 0
L Auto-set followup/reminder popup box for ALL sent emails. Using Outlook 0
P VBA for Dialog Box when sending Email Using Outlook 8
M Send receive Progress Box Using Outlook 4
