Combo Box
hi....just in case.....look into yet....would love to fix it soon!!
The only way i see to fix it is to open the contact from the contacts folder. The inspector isn't called "correctly" when you open it from contact linking.
I suppose you could use a macro that searches for the linked contact and opens it, but i don't have a code sample that does it and have a project deadline coming up, so no time to work on it. I'm not even 100% sure it would work. I do know you can open two copies of a contact when one is opened from the contact linking field or a shortcut/embedded object.
what does this mean please:
Sorry, I didn't see it yesterday.
Normally, you can't open a contact twice. If you have a contact open and go back into the contacts folder and double click on it, you'll bring the opened contact into focus.
When you open a contact from the Contact linking field or a shortcut, Outlook can't "see" it's open - if you go into Contacts folder and double click, it will open the contact again.
thanks...but that doesn't help what I am trying to do re the macros regarding the combo box structure you showed me how to do ....
just so you know, when I open the contact from the shortcut, the macros we first created that each one is an email template that recognizes the email address of the contact, these work...
so the macros re the combo box you showed me how to do, is the macros that do not work from the contact opening up from the shortcut.
Any last thoughts on this?
Yes. I don't know the structure. The individual macros work but the userform and related module don't work when the contact is opened from the shortcut to it in the calendar event
I would think it could be fixed.
Here is the useform example....Which word Private should be changed please?
Private Sub ComboBox1_Change()
Private Sub ComboBox8_Change()
Private Sub UserForm_Initialize()
With ComboBox8
.AddItem "Today-Meeting_Thank-You_Friend"
.AddItem "Recent-Meeting_Thank-You_Friend"
.AddItem "Recent-Meeting_Thank-You_Network_Contact"
.AddItem "Today_Meeting_Thank-You_Network_Contact"
.AddItem "Today-Meeting_Thank-You_Friend_Genesis_VII"
.AddItem "Recent-Meeting_Thank-You_Friend_Genesis_VII"
Private Sub CommandButton5_Click()
lstNum2 = ComboBox8.ListIndex
Unload Me
so where else can I ask the question as the microsoft forum does not respond and the phone call to microsoft does not solve it....
ps...i do believe you can figure it out as you are the best!!
I appreciate your time as usual. My guess is there is a way to fix it. Are there any other forums or people I should contact and see what they say?
thank you....i posted there before and basically no one has answered.....any other thoughts?
a couple of responses tell me to put a breakline on the first line and see what happens...
can you possible tell me in detail how I add a breakline to the first line please?
P Custom Outlook form_Validations in combo box Outlook VBA and Custom Forms 0
S Outlook form - Combo box for deciding who to send form to Using Outlook 1
M details with the combo box Exchange Server Administration 3
Q Follow up: Make a combo box dependant on another Outlook VBA and Custom Forms 6
Q Make a combo box dependant on another Outlook VBA and Custom Forms 5
Q Load a recipient based on a value in a combo box Outlook VBA and Custom Forms 7
F Outlook 2010 - outlook userform and combo boxes Using Outlook 9
M Need help with combo boxes in messages! Using Outlook 10
A Search People>press enter box disappears. Using Outlook 3
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
A GetSelectNamesDialog Pre-fill search box Outlook VBA and Custom Forms 12
K Sharedmail box Outlook VBA and Custom Forms 4
Diane Poremsky Outlook Suggestion Box at Uservoice Using Outlook 0
D Emails do not appear in Sent box! Using Outlook 4
Kristine RS box added in Favorites disappears Using Outlook 6
rohit I want to Populate Popup box while sending any email with attachment. Outlook VBA and Custom Forms 4
rohit I want to Populate Popup box while sending any email with attachment Using Outlook 1
Ross Garvey Dialogue box opens as I exit Using Outlook 2
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
G Enter Network Password box pops up every few seconds Using Outlook 2
V In Box Issues Using Outlook 1
S Custom yes/no message box. Using Outlook 0
