Views with the ToDo Bar and Navigation Pane
DigitalDawn
Outlook 2019 32-bit
I was playing with various view configurations in Outlook 2007 and the following work best for me:
Calendar view with a large ToDo bar and no navigation pane.
Contacts with no ToDo Bar and No Nav pane.
Mail with no ToDo Bar but with a Navigation pane.
Is there a way for Outlook to remember these settings when I switch to each section?
I wasn't sure whether or not the Define Views settings would save the Nav pane and ToDo Bar positions.
Unfortunately, no. It's all or nothing in Outlook 2010 and older.
Outlook 2013 supports different configured for folder types though - it's one of the few redeeming qualities in the "new and improved" to-do bar.
H Outlook 2007 SQL syntax to filter views of tasks and todo items Outlook VBA and Custom Forms 1
S Different views for To-Do List and To-Do Bar Using Outlook 0
V Outlook 2021 Can anyone explain why my Outlook views keep changing?! Using Outlook 2
A Connect to server to views items Using Outlook 0
J Office 365 erased all of my task views Using Outlook 3
Jennifer Murphy To Do List Views Using Outlook 0
S Views ans Where Settings AreSavd Using Outlook 4
avant-guvnor Outlook 2016 and views, categories etc. Using Outlook 3
Witzker Change icon for custom views Using Outlook 1
Z Batch Change Folder Views in Outlook 2016 Using Outlook 1
P Duplicate Standard Views Using Outlook 3
H User designed fields not usable in contact folder views Using Outlook 0
piusg 2013: Task Views keep disappearing Using Outlook 4
Brian Outlook List of custom task views missing in OL2013 Using Outlook 2
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
J Calendar Views (2013) are Blank Using Outlook 1
R Filter Views by Category Using Outlook 2
S How do I get the default Outlook 2007 Contacts Views back? Using Outlook 3
T save custom user settings/ views BCM (Business Contact Manager) 2
L Outlook 2007 Macro For Views Using Outlook 10
A lock task views? Using Outlook 11
M Apply different views to calendars Using Outlook 0
D Cannot delete shared contact or calandar from views Exchange Server Administration 1
B OWA Calendar Views not available Exchange Server Administration 2
A In Contacts Phone List View, allow alpha jump w/single key, same as Card views Using Outlook 4
D Zoom in Microsoft Outlook Views? (Not Messages) Using Outlook 2
J Export custom views from offline OST Exchange Server Administration 4
J How to disable syncing folder views/layouts Using Outlook 5
A Views on multiple folders Outlook VBA and Custom Forms 2
E use only views defined for this folder Outlook VBA and Custom Forms 2
T Creating Task Views Methodically Outlook VBA and Custom Forms 7
W Using a PropertyAccessor custom datetime property in Views Outlook VBA and Custom Forms 3
D Business Contact Views BCM (Business Contact Manager) 2
D Changing calendar views Outlook VBA and Custom Forms 10
U Drops filters for published views in public folders.Inserts DASL Outlook VBA and Custom Forms 1
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 0
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
M tasks in todo list appearing twice Using Outlook 3
S Custom view in todo bar with "Today," "tomorrow" groupings Using Outlook 2
A change the "no date" header in todo bar Using Outlook 2
C Search bar moved on its own? Using Outlook 4
A Relocate Search Bar in Outlook Using Outlook 2
ad24rouse Column Width of To-Do Bar Using Outlook 5
