Auto-conversion mail to task
pabe1250
Hi!
I'm having kind of a challenge.
I'm trying to redirect received e-mails from a shared account in Outlook to a SharePoint task list. By doing so two steps are required:
1. Converting the received e-mail in the shared account's inbox to a task - which unfortunately, as I understand it, with no way of redirecting it, will end up in that same shared account's task list in Outlook.
2. Move the task from that account's task list to the SharePoint task list.
I found a Macro that converts the e-mail to a task and it works perfectly. And if I mark, drag and drop the task from the Outlook default task list in to the SharePoint list it works just fine, but when I try to use a Macro doing this it just doesn't work. If I put up a rule telling that all received e-mails in this account should be moved to that SharePoint list and then run the Macro to convert it to a task, it just moves the e-mail. The conversion never takes place. Though if I just run the conversion Macro it really works. The e-mail becomes a task - but unfortunately placed in the wrong directory.
It seems as if the Macro can't be run after a move on the e-mail has occured.
Any work-arounds? Preferably a way to do this on the local machine since involving other departments further up the ladder will just add to my hardship:D
Thanks in advance!
/Paul
The macro *should* work. It would save the mail as a task in outlook's task folder then move it to sps. I would definitely do a save to outlook's task folder then move to sps. Which macro are you using?
This is the Macro:
Sub ConvertMailtoTask(Item As Outlook.MailItem)
Dim objTask As Outlook.TaskItem
Set objTask = Application.CreateItem(olTaskItem)
With objTask
.Subject = Item.Subject
.StartDate = Item.ReceivedTime
.Body = Item.Body
.Save
Set objTask = Nothing
Set SPSFolder = GetFolderPath("SharePoint Lists\Any_given_subfolder")
objTask.Save
objTask.Move SPSFolder
When run I get a compilation error "Sub or Function has not been defined" and it jumps to "GetFolderPath" which turns blue. Any ideas?
You need the GetFolderPath function - Working with VBA and non-default Outlook Folders - Slipstick Systems
Not tested, but this should work -
'move this up here just to get it out of the way
' this creates and saves the task
With objTask
.Body = Item.Body
.Save
' this can go right before 'end with' (if so remove ojbtask from it)
' this goes last, before the sub ends
Thanks Diane! It really helps me:rolleyes:
So the GetFolderPath function goes before the code you wrote?
Is it enough to state: Set Items = GetFolderPath("SharePoint Lists\Any_given_subfolder").Items
....is the function included in the system or is it needed to include the whole code - like this?
Function GetFolderPath(ByVal FolderPath As String) As Outlook.Folder
[TD="class: content"] Dim oFolder As Outlook.Folder[/TD]
[TD="class: content"] Dim FoldersArray As Variant[/TD]
[TD="class: content"] Dim i As Integer[/TD]
[TD="class: content"] [/TD]
[TD="class: content"] On Error GoTo GetFolderPath_Error[/TD]
[TD="class: content"] If Left(FolderPath, 2) = "\\" Then[/TD]
[TD="class: content"] FolderPath = Right(FolderPath, Len(FolderPath) - 2)[/TD]
[TD="class: content"] End If[/TD]
[TD="class: content"] 'Convert folderpath to array[/TD]
[TD="class: content"] FoldersArray = Split(FolderPath, "\")[/TD]
[TD="class: content"] Set oFolder = Application.Session.Folders.item(FoldersArray(0))[/TD]
[TD="class: content"] If Not oFolder Is Nothing Then[/TD]
[TD="class: content"] For i = 1 To UBound(FoldersArray, 1)[/TD]
[TD="class: content"] Dim SubFolders As Outlook.Folders[/TD]
[TD="class: content"] Set SubFolders = oFolder.Folders[/TD]
[TD="class: content"] Set oFolder = SubFolders.item(FoldersArray(i))[/TD]
[TD="class: content"] If oFolder Is Nothing Then[/TD]
[TD="class: content"] Set GetFolderPath = Nothing[/TD]
[TD="class: content"] Next[/TD]
[TD="class: content"] 'Return the oFolder[/TD]
[TD="class: content"] Set GetFolderPath = oFolder[/TD]
[TD="class: content"] Exit Function[/TD]
[TD="class: content"]GetFolderPath_Error:[/TD]
End Function
/Paul
I always put it after - actually, I have a module called 'functions' where this function and a function that works on open or selected items are saved so I can use them in any macro - but if you are putting it in the same module, put it after your macro.
You need the whole code - call it in your macro as Set SPSFolder = GetFolderPath("SharePoint Lists\Any_given_subfolder"), just like in the code sample posted earlier.
Thanks again. It finally worked like a charm:)
Did a silly mistake though since my system is in swedish where "SharePoint Lists" is "SharePoint-listor". Therefore the path was screwed up and eventhough the macro ran without any faults, the actual move of the task went to a non-existing folder.
Tack så mycket:)
Hornblower409 Hyperlinks - Disable Auto Complete Using Outlook 0
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
C New pc, new outlook, is it possible to import auto-complete emailaddress Using Outlook 5
F Auto changing email subject line in bulk Using Outlook 2
